[Unity] Unity打包Android报错 用gradle build打包时报错
查看:543 |回复:1 | 2022-2-8 11:04:55
用gradle build打包时报以下错
To run dex in process, the Gradle daemon needs a larger heap.
It currently has 1024 MB.
For faster builds, increase the maximum heap size for the Gradle daemon to at le
ast 1536 MB.
To do this set org.gradle.jvmargs=-Xmx1536M in the project gradle.properties.
For more information see https://docs.gradle.org/current/userguide/build_environ
ment.html
原因:gradle需要更大内存
解决方案: 修改gradle-wrapper.properties文件。
在gradle-wrapper.properties文件中添加一条配置
set  org.gradle.jvmargs=-Xmx2048m -XX:MaxPermSize=2048m
2022-2-8 11:04:55
1个回答,把该问题分享到群,邀请大神一起回答。
2023-3-1 11:05:05   回复
