[Unity] Unity发布WebGL报错Could not produce class with ID 91.
查看:536 |回复:4 | 2022-2-8 11:14:30
控制台报错:Could not produce class with ID 91.
This could be caused by a class being stripped from the build even though it is needed. Try disabling 'Strip Engine Code' in Player Settings.
现象:角色人物没有播放动画
查询https://docs.unity3d.com/Manual/ClassIDReference.html发现91号类为AnimatorController
修正:Project Setting – Player – Other Setting, 去掉勾选 Strip Engine Code*
2022-2-8 11:14:30
4个回答,把该问题分享到群,邀请大神一起回答。
能有效解决
2022-2-8 21:51:31   回复
Strip Engine Code去掉了 那你用不到的组件不也被打进你的WebGL包了么   是不是你的剥离等级设置的太高导致你需要的组件被剥离了
2022-3-17 08:59:28   回复
如此充满诚意的回答,我只能点赞了,专业回答,学习了
2022-4-6 09:25:34   回复
2022-4-11 09:17:33   回复
