程序化贴图 [sbsar格式] 【自购】Substance Utility Node | Dete Shadow Box-实用程序节点| Dete阴影框
6910
15
价格:50 元素币 百度网盘 收益:1200元素币 销量:24
尊敬的游客 ,本内容需要支付后可见.
提醒使用【余额支付】需要: ¥5 余额
此资源为Standard License版本
In a collaboration with my good friend and techartist Ppang, we decided to introduce the concept of 3d mesh creation inside Substance Designer with a new Shadow Box tool. The way it works is that you input shapes into the x,y,z inputs. These get extruded according to their axis and the end result is the intersection of all the shapes.
Features
  • Create and design intricate 3d shapes directly in substance designer
  • Input 2d masks for all X Y Z axis. The shapes are extruded and the resulting shape is the intersection of the combined shapes.
  • Shapes can be rotated to any orientation.
  • With the outputs of position and normals you can also Texture your 3d shape using the existing triplanar node.
Limitations
  • This node takes its time to calculate there is no doubt about it. The results speak for themselves but use it with a bit of patience.
  • Because of the shape generation slicing process, there is a bit of noise artifacts along the surface, for best results combine it with a ‘Blur HQ‘ node (0,3 and quality 1).
  • Twisting does not yet work with Position and Normal outputs.
Contents
1 Sbsar file
Created using Substance Designer 10.1.1
License
Personal, Small Business, and Studio/Educational Licenses are available. Personal licenses do NOT apply to companies or organizations. Sharing, streaming, and redistribution to third-party is strictly prohibited.
Digital products are non-refundable
在与我的好朋友和技术艺术家 Ppang 的合作中,我们决定使用新的 Shadow Box 工具在 Substance Designer 中引入 3d 网格创建的概念。它的工作方式是将形状输入到 x,y,z 输入中。这些根据它们的轴被挤压,最终结果是所有形状的交集。
特征
  • 直接在物质设计师中创建和设计复杂的 3D 形状
  • 为所有 XYZ 轴输入 2d 蒙版。形状被挤出,得到的形状是组合形状的交集。
  • 形状可以旋转到任何方向。
  • 通过位置和法线的输出,您还可以使用现有的三平面节点纹理您的 3d 形状。
限制
  • 这个节点需要时间来计算,这是毫无疑问的。结果不言自明,但请耐心使用它。
  • 由于形状生成切片过程,表面存在一些噪声伪影,为获得最佳效果,请将其与“模糊 HQ”节点(0,3 和质量 1)结合使用。
  • 扭转不适用于位置和正常输出。
内容
1个Sbsar文件
使用 Substance Designer 10.1.1 创建
参与人数 3 元素币 +22 活跃度 +19
许多人想登上月球,而我却想多看看树。
熾天之翼  发表于 2022-4-19 08:39:47
wangzhenmo  发表于 2022-4-19 13:59:47
yu_meng123  发表于 2022-4-20 09:49:15
带你赚币带你飞,元素里面有正妹。
扼住命运的咽喉  发表于 2022-11-21 16:21:20
狂奔de蜗牛  发表于 2022-12-28 12:03:08
canghai1  发表于 2022-12-28 17:28:57
带你赚币带你飞,元素里面有正妹
幸运の兔脚  发表于 2023-8-11 11:08:05
666666666666666666
q121080521 实名
优质搬运工
18 小时
长剑 长枪
