场景-物件-植被 [树木_花草_植被] 【DAZ】Creeping Ferns - Polypody-攀缘植物-蕨类植物-多足植物-灌木-草
1677
7
3D资源
3D资源分类: 低模
资源题材: 现实
美术风格: 写实
3D资源格式: DAZ
贴图规格与格式: PBR规格
软件版本要求: 未知或无明确软件版本限制
价格:150元素币(或15余额) 百度网盘 销售总额:750元素币 购买人数:5
尊敬的游客 ,本内容需要支付 150元素币十分之一的[余额] 来购买.
Details
Got a wall that needs some wildlife? Look no further than Creeping Ferns - Polypody, a bundle of 38 high-detail models of Polypodium vulgare!
The common polypody fern can be found growing on rocks, walls, and shady ground all over the UK, Europe, and North America, as well as other temperate regions of the world. It's the perfect foil to mossy rocks and masonry and instantly softens the edges of ruins, walls, paving, and even containers.
This great big selection of versions of this little fern includes both horizontal and vertical single stems, clumps, and even wall toppers with rhizomes spilling over one side of a square-topped object. With lots of material options, you can choose between 3 types of foliage, red and green stems, and whether or not you wish to see the rhizomes.
As always, a little goes a long way and with these plants. Slight variation in scale and also the Y rotation can make one plant look totally different to an identical instance, or duplicate it in just a couple of clicks!
So whether you want to give a statue a hairdo, cover the top of a wall or column with fronds, or spread instances of this lovely fern all over a vertical cliff face or rock surface, the Creeping Ferns - Polypody will help you achieve that extra bit of realism in your renders!
What's Included and Features
Creeping Ferns - Pollypoddy
  • WFWF Pollypody Wall Topper 01a
  • WFWF Pollypody Wall Topper 01b
  • WFWF Pollypody Wall Topper 01c
  • WFWF Pollypody Wall Topper 02a
  • WFWF Pollypody Wall Topper 02b
  • WFWF Pollypody Wall Topper 02c
  • WFWF Pollypody Wall Topper 03a
  • WFWF Pollypody Wall Topper 03b
  • WFWF Pollypody Wall Topper 03c
  • WFWF Polypody Horizontal Large 01a
  • WFWF Polypody Horizontal Large 01b
  • WFWF Polypody Horizontal Large 01c
  • WFWF Polypody Horizontal Large 02a
  • WFWF Polypody Horizontal Large 02b
  • WFWF Polypody Horizontal Large 02c
  • WFWF Polypody Horizontal Small 01a
  • WFWF Polypody Horizontal Small 01b
  • WFWF Polypody Horizontal Small 01c
  • WFWF Polypody Horizontal Small 02a
  • WFWF Polypody Horizontal Small 02b
  • WFWF Polypody Horizontal Small 02c
  • WFWF Polypody Horizontal Small 03a
  • WFWF Polypody Horizontal Small 03b
  • WFWF Polypody Horizontal Small 03c
  • WFWF Polypody Horizontal Small 04a
  • WFWF Polypody Horizontal Small 04b
  • WFWF Polypody Horizontal Small 04c
  • WFWF Polypody Horizontal Small 05a
  • WFWF Polypody Horizontal Small 05b
  • WFWF Polypody Horizontal Small 05c
  • WFWF Polypody LR Horizontal 01a
  • WFWF Polypody LR Horizontal 01b
  • WFWF Polypody LR Horizontal 02a
  • WFWF Polypody LR Horizontal 02b
  • WFWF Polypody LR Instance Vertical 01a
  • WFWF Polypody LR Instance Vertical 01b
  • WFWF Polypody LR Instance Vertical 02a
  • WFWF Polypody LR Instance Vertical 02b
Materials Presets
  • WFWF Polypody Base Foliage Mat
  • WFWF Polypody Foliage A Mat
  • WFWF Polypody Foliage B Mat
  • WFWF Polypody Foliage C Mat
  • WFWF Polypody Foliage Full Mat
  • WFWF Polypody Foliage Sparse Mat
  • WFWF Polypody Rhizomes Gone Mat
  • WFWF Polypody Rhizomes Visible Mat
  • WFWF Polypody Stems Green Mat
  • WFWF Polypody Stems Red Mat
Textures Included
  • 12 Texture, Displacement, Normal, Specular, and Transparency Maps (up to 2000 x 2000)
Daz Studio material Presets for Iray (.DUF)
细节
有一堵墙需要一些野生动物?看看 Creeping Ferns - Polypody 吧,它包含 38 个Polypodium v​​ulgare 的高细节模型!
常见的多足蕨类植物生长在英国、欧洲和北美以及世界其他温带地区的岩石、墙壁和阴凉的地面上。它是苔藓岩石和砖石的完美陪衬,可立即软化废墟、墙壁、铺路甚至容器的边缘。
这种小蕨类植物的大量版本包括水平和垂直的单茎、丛,甚至是带有根茎的墙顶饰物,其根茎溢出到方形顶物体的一侧。有很多材料可供选择,您可以选择 3 种类型的叶子,红色和绿色的茎,以及您是否希望看到根茎。
与往常一样,对于这些植物来说,有一点很长的路要走。规模的微小变化以及 Y 旋转可以使一株植物看起来与相同的实例完全不同,或者只需单击几下即可复制它!
因此,无论您是想给雕像做个发型,用叶子覆盖墙壁或柱子的顶部,还是将这种可爱的蕨类植物的实例散布在垂直的悬崖面或岩石表面,爬行蕨类植物 - 多足动物将帮助您实现额外的目标渲染中的真实感!
包含的内容和功能
  • 爬行蕨类植物 - Pollypoddy
  • WFWF Pollypody 墙饰 01a
  • WFWF Pollypody 墙饰 01b
  • WFWF Pollypody 墙饰 01c
  • WFWF Pollypody 墙饰 02a
  • WFWF Pollypody 墙饰 02b
  • WFWF Pollypody 墙饰 02c
  • WFWF Pollypody 墙饰 03a
  • WFWF Pollypody 墙饰 03b
  • WFWF Pollypody 墙饰 03c
  • WFWF Polypody 卧式大号 01a
  • WFWF Polypody 水平大号 01b
  • WFWF Polypody 卧式大号 01c
  • WFWF 多足卧式大号 02a
  • WFWF Polypody 水平大 02b
  • WFWF Polypody 卧式大号 02c
  • WFWF 多足卧式小型 01a
  • WFWF 多足卧式小型 01b
  • WFWF Polypody 卧式小号 01c
  • WFWF 多足卧式小 02a
  • WFWF 多足卧式小型 02b
  • WFWF 多足卧式小号 02c
  • WFWF 多足卧式小型 03a
  • WFWF 多足卧式小型 03b
  • WFWF Polypody 卧式小型 03c
  • WFWF 多足卧式小型 04a
  • WFWF 多足卧式小型 04b
  • WFWF 多足卧式小号 04c
  • WFWF 多足卧式小型 05a
  • WFWF 多足卧式小型 05b
  • WFWF Polypody 卧式小号 05c
  • WFWF Polypody LR 水平 01a
  • WFWF Polypody LR 水平 01b
  • WFWF Polypody LR 水平 02a
  • WFWF Polypody LR 水平 02b
材料预设
  • WFWF Polypody 基础植物垫
  • WFWF 多足植物 B 垫
  • WFWF 多足植物稀疏垫
  • WFWF 多足根状茎消失垫
  • WFWF 多足根茎可视垫
  • WFWF 多足茎绿色垫
  • WFWF 多足茎红垫
包括纹理
  • 12 个纹理、置换、法线、高光和透明度贴图(最高 2000 x 2000)
适用于 Iray (.DUF) 的 Daz Studio 材质预设
参与人数 1 活跃度 +20
昕晨  发表于 2022-5-5 21:25:24
qq_玄嚣_snG  发表于 2022-5-6 10:43:28
qq_哈达_ff2  发表于 2022-5-6 15:04:11
6666666666666666666
MJ漫步  发表于 2022-5-6 18:24:06
感谢楼主精彩分享
haha123  发表于 2022-5-7 19:15:09
感谢楼主分享的精彩资源,收藏了!!
Lam 实名
12 小时
光之杖 友情药水 长剑 扩散者 幻焱之玉 长枪 元素季卡
