--------熔炉4 Fluent Power Trip v2.06 Fluent2.06
149
4
With more than 40 updates in 2 years, Fluent is an actively developed tool.
强大流畅无压力轻松建模工具布尔建模插件
Why Fluent is the greatest tool ever made ?User-friendly
A slick interface with a simple menu. It's all you need.
Accurate drawing
Fluent's snapping grid and precision tools allow you to aim perfectly at any section of a polygon or edge. Fluent is the ideal solution for advanced hard surface work. Guaranteed to bullseye womp rats at a thousand yards.
Completely Non-destructive
If you're knee-deep in details and after 30 hours you want to change something, don't worry. No, you don't have to cry. Fluent is completely non-destructive! It's all modifiers, baby! Feel free to go back and adjust any parameter as you bring your idea to life.
Get Fast. Real Fast.
As you become more fluent in Fluent, you will start using its handy hotkeys. With a bit of time and practice, you'll get so fast that your friends will think you're a Jedi in a Power Ranger outfit going Super Saiyan.
Smart Tools
Fluent was designed with a high level of efficiency in mind. The addon will take care of your work and remember your settings. As an example, boolean have their own collections, boolean objects have color ID's, and bevel settings are remembered for later use.
Zero Learning Curve
You can start by diving in and exploring the tool directly. You're guaranteed to start figuring things out in just a few minutes, even without a tutorial. When you want to go deeper and see what other secrets Fluent has in store, go to our dedicated YouTube channel for detailed documentation and step-by-step tutorials.
Some featuresDrawing
  • Rectangle/Square from corner/center.
  • Circle.
  • Random shape.
  • Solid of revolution.
  • Every face of the model are drawing plans.
User-friendly
  • Fly menu, all edition tools are here and only here, do not search everywhere.
  • Mirror and array widget for easy direction selection.
  • All informations on the screen, to know everything everytime.
  • No visual pollution, see only what you need when you need.
  • Everything is in the viewport.
  • Automatic bevel resolution, stop wasting your time to set each bevel segments.
  • etc...
Accurate drawing
  • Display the snap grid on everyface.
  • A menu to easly adjust the resolution, the scale and the rotation of the grid.
  • Align the grid along an edges to draw in the edge direction.
  • Use the grid to make solids of rotation.
  • Direction snap during the hand drawing.
Non destructive workflow
  • It's simple : EDIT EVERYTHING AT ANY TIME
  • Circular array, symetrize, inset, linear array, mirror...
  • 3 level of bevels and 2 level of solidify.
Smart tool box to manage whole the model in one click
  • Duplicate tool.
  • Boolean synchronization, to spread the adjustment to every duplicated object.
  • Global bevel factor, to increase/decrease each bevel of the model.
  • Bevel resolution, one click to adjust the bevel segments of everything.
  • Auto-boolean support making, to fix classic boolean error.
  • Auto-complete, to apply modifiers and get a freezed mesh.
Model incredibly detailed models with the Power Trip version
  • Add plates.
  • Place pipes between two faces with 2 clicks.
  • Place wires between two faces. Wiht only 2 clicks, 6 models.
  • Add grids in any holes cutted with Fluent. 14 models of grids.
  • Add fabric panels with only 2 clicks.
Testimonials by ProfessionalsI like Fluent because it's useful for just about everything. Its versatility is tremendous.
Fluent isn’t strictly tied to scifi work, nor is it cornered into high-poly render models. I've used Fluent to create low-poly props as well, ranging from robot arms to structures like stone temples and shrines. Its boolean system is perfectly suited to creating complex designs for any purpose, even in ultra low-poly props & models.
Fluent is the ultimate cutting tool and was designed to modify truly complex geometry. The tool has a great deal of precision when it comes to the arcane angles of 3D space. If I need to cut into an archway or a circular doorframe, the treads of a tire, or even to cut out the pattern on the bottom of a shoe… that’s what Fluent is perfect for. You’ll find yourself using it on a daily basis, almost as frequently as the extrude command.
I like to combine Fluent with Zremesher 3.0. It’s the ultimate weapon for fast and detailed high-poly props. Try it out!
Rudy Michau, the developer
I have often been asked why I created Fluent.
When I began hard surface modeling, I eagerly tested the other tools available for this type of work. There are some great tools out there, and many are very inspiring to my own work. Unfortunately, at the time, I became frustrated with the sheer number of hotkeys and menus to remember. Not only that, but a lot of those tools were destructive, not taking full advantage of Blender's modifier stack. I never finished a model and I always got discouraged before the end. I felt like the whole process could be simplified and streamlined.
I am a Blender user who, like so many others, strives to make great art. It’s hard work! I'm not one of those geniuses who remembers how to do something after the first try. I like to tinker & try different things, and re-adjust my methods according to new projects. I didn’t want to memorize another dozen hotkeys on top of the existing Blender arsenal… I wanted a tool that was simple to use, yet fast and efficient.
From this experience was born the desire for a tool that could solve these problems, not just for myself but for every Blender user who encountered the same difficulties. That's why I put in the time and developed Fluent, according to these three criteria: user-friendly, non-destructive, and precision.
In only six months⁠— with the love and support of a fantastic community⁠— Fluent has become an essential tool for hard surface artists. Meanwhile, others are discovering uses that I would’ve never thought of, such as the modeling of an ancient temple!
Fluent has allowed me to make⁠— with great pleasure⁠— my first model of the hard surface type. It is this pleasure that I hope you find when you use Fluent for your own creations. This is what I love, and this is my livelihood.
一些功能绘图
  • 矩形/正方形从角落/中心。
  • 圈。
  • 随机形状。
  • 革命的坚实。
  • 模型的每个面都在绘制平面图。
用户友好
  • 飞菜单,所有版本工具都在这里,只有在这里,不要到处搜索。
  • 镜像和阵列小部件,便于选择方向。
  • 屏幕上的所有信息,每次都知道一切。
  • 没有视觉污染,只在你需要的时候看到你需要的东西。
  • 一切都在视口中。
  • 自动斜面分辨率,停止浪费时间设置每个斜角段。
  • 等。。。
精确绘图
  • 在每个表面上显示对齐网格。
  • 一个菜单,用于轻松调整网格的分辨率,比例和旋转。
  • 沿边对齐网格以沿边方向绘制。
  • 使用栅格制作旋转实体。
  • 手绘过程中的方向捕捉。
非破坏性工作流程
  • 这很简单:随时编辑所有内容
  • 圆形阵列,对称,插图,线性阵列,镜像...
  • 3级斜面和2级凝固。
智能工具箱,一键式管理整个模型
  • 复制工具。
  • 布尔同步,将调整范围扩展到每个重复的对象。
  • 全局斜角因子,用于增大/减少模型的每个斜角。
  • 斜面分辨率,一键调整所有东西的斜面段。
  • 自动布尔支持制作,以修复经典的布尔错误。
  • 自动完成,以应用修饰符并获取冻结的网格。
使用Power Trip版本对令人难以置信的详细模型进行建模
  • 添加盘子。
  • 通过单击 2 次将管道放置在两个面之间。
  • 在两个面之间放置电线。只需点击2次,6个型号。
  • 在用 Fluent 切割的任何孔中添加网格。14种网格模型。
  • 只需单击 2 次即可添加织物面板。
专业人士的感言我喜欢Fluent,因为它对几乎所有东西都很有用。它的多功能性是巨大的。Fluent与科幻作品没有严格联系,也没有被逼入高多边形渲染模型。我也使用Fluent来创建低多边形道具,从机器人手臂到石庙和神社等结构。它的布尔系统非常适合为任何目的创建复杂的设计,即使在超低多边形道具和模型中也是如此。Fluent 是终极切削刀具,旨在修改真正复杂的几何形状。当涉及到3D空间的神秘角度时,该工具具有很高的精度。如果我需要切入拱门或圆形门框,轮胎的胎面,甚至切掉鞋底的图案......这就是Fluent的完美之处。您会发现自己每天都在使用它,几乎与挤出命令一样频繁。我喜欢将Fluent与Zremesher 3.0相结合。它是快速和详细的高多边形道具的终极武器。试试吧!
经常有人问我为什么创建Fluent。当我开始硬表面建模时,我热切地测试了可用于此类工作的其他工具。有一些很棒的工具,许多对我自己的工作非常鼓舞人心。不幸的是,当时,我对要记住的热键和菜单的绝对数量感到沮丧。不仅如此,而且很多这些工具都是破坏性的,没有充分利用Blender的修饰符堆栈。我从来没有完成过一个模型,我总是在结束之前感到气馁。我觉得整个过程可以简化和精简。我是Blender的用户,像许多其他人一样,我努力创造伟大的艺术。这是艰苦的工作!我不是那种记得在第一次尝试后如何做某事的天才之一。我喜欢修补和尝试不同的东西,并根据新项目重新调整我的方法。我不想在现有的Blender武器库之上记住另外十几个热键......我想要一个简单易用、快速高效的工具。从这次经历中诞生了对可以解决这些问题的工具的渴望,不仅对我自己,而且对每个遇到相同困难的Blender用户来说都是如此。这就是为什么我投入时间并开发Fluent,根据这三个标准:用户友好,无损和精确。在短短六个月的时间里 - 在一个梦幻般的社区的爱和支持下 - Fluent已成为硬表面艺术家必不可少的工具。与此同时,其他人正在发现我从未想过的用途,例如古代寺庙的建模!Fluent 让我非常高兴地制作了我的第一个硬表面模型。我希望您在使用Fluent进行自己的创作时能找到这种乐趣。这就是我所爱的,这就是我的生计。
收模型,杂志,教程,插图,插件,软件,拿来卖。
逆水寒  发表于 2022-5-22 22:01:40
NN12323123 : 是中文的嘛
2022-5-30 20:22 回复
小葱夜  发表于 2023-2-27 19:36:55
sdfadf sadfas fasfdasfdasfg dbxg
请叫我艺术家  发表于 2023-5-13 22:57:55
Qingxiao14  发表于 2023-5-22 23:04:06
DiGiToTo 实名
大自然的搬运工
7829 小时
翡翠剑 【绝】红龙战甲 学徒法袍 赤铁剑 英雄盾 铁剑 钢盾 元素之盾 钢剑 长剑 水晶剑 死亡刃 阿鼻剑 鬼道剑 修罗剑 天子剑 天道剑 元素铜币 元素银币 元素金币 元素秘币 元素圣币 短杖 圣杖-【安东尼达斯】 【绝】珍珠戒指 女皇之泪 长枪 双杀 巨浪 龙枪 深渊 战神 魔神战甲 元素之铠 黄金圣衣 相对时空 征战护手 【绝】结界玄晶 神界之石 六界传音 【绝】大天使权杖 微光灵石 圣盾-【瓦雷利亚】 【绝】盘古斧 魔镜 裁决 神速靴 火元素 暴风之眼 元素之钻 秘法之钻 血精之钻 波塞冬之叉 圣光之钻 小苹果 大菠萝 再造药水 黄色药水 蓝色药水 赤色药水 微库VIP 翠晶之钻 紫晶之钻 扩散者 钢铁矿镐 秘银矿镐 黄金矿镐 彗星钛晶矿 阿尔法晶矿 泰坦高能矿 守望者【EX】 守望者【赤炼】 守望者【天使】 【绝】守望者【死神】 希望人没事 吃鸡头盔 吉普车 吃鸡甲 守望者【猎空】 生命之缘 自然之怒 原初葫芦 冰晶剑 玫瑰金项链 烈-红龙战甲 【绝】真-红龙战甲 【绝】千人纪念徽章 橙色药水 青色药水 一星珠 二星珠 七星珠 赛博空间 天体物理 宏观物质 无色原始矿 绿母翠晶矿 超星赤辉矿 怀特紫星矿 飞雷靴 现实宝石 灵魂宝石 心灵宝石 时间宝石 力量宝石 粒粒皆辛苦 【绝】赤影战盔 【绝】赤影战斧 莆田鞋 魔法扫帚 朝阳之光 光明勋章 魔法帽 【绝】烈龙战甲 【绝】魔焰斧 【绝】碧焰指环 烈火长枪 烈火匕首 粉御之钻 青戒之钻 黄金沙鹰 金阳之水 紫雷之水 青息之水 粽子 天蓝靴 光虹靴 紫霞之秋 源力法杖 【魔剑】龙葵之魂 绿色药水 紫色药水 光之杖 水晶杖 血晶杖
