价格:200元素币 (或20余额)
百度网盘
销售总额:6600元素币 购买人数:33
A站链接:https://www.artstation.com/marke ... high-lowpoly-meshes
There are 63 sci-fi IMM crved brush chains for zbrush and each brush has 2 versions high and low poly. Also you can have all meshes. Simple to use, just select one chain on the chain Imm panel , drag a curve, change the size if needed and it's done ! How to use : All Brushes have the correct settings embedded but just in case you need it : Please check guide file there are pictures for this issue. When using the brush make sure to turn on Curve mode under the Stroke - Curve menu. This Brush has Tri-part ropes and Non-Tri-parts ropes For Tri-Part ropes (see pictures for reference) --> Tri-part should be turned ON. (Brush-->Modifier-->Tri-parts) and Weld points should be turned on and also crv res is better to be on 5 degree. For Non-TriPart ropes (see pictures for reference) --> Tri-part should be turned OFF. (Brush-->Modifier-->Tri-parts) and Weld points should be turned on and also crv res is better to be on 5 degree. pack includes:
63 lowpoly IMM crved brush with and without ends (ZBP).
63 highpoly IMM crved brush with and without ends (ZBP).
63 lowpoly meshes in 3 format OBJ, FBX AND BLEND.
63 highpoly meshes in 3 format OBJ, FBX AND BLEND.
zbrush 有 63 个科幻 IMM crved 画笔链,每个画笔有 2 个版本的高多边形和低多边形。您也可以拥有所有网格。 使用简单,只需在链 Imm 面板上选择一条链,拖动一条曲线,根据需要更改大小即可! 如何使用: 所有画笔都嵌入了正确的设置,但以防万一你需要它: 请检查指南文件,有此问题的图片。 使用画笔时,请确保打开“描边 - 曲线”菜单下的“曲线”模式 。 这把刷子有三部分绳索和非三部分绳索 对于三部分绳索(参见图片以供参考)-> 三部分应打开。(画笔-->修改器-->三部分) 并且焊接点应该打开, 并且crv res最好是5度。 对于非三部分绳索 (参见图片以供参考)-> 三部分应关闭。( Brush-->Modifier-->Tri-parts ) 和 Weld points 应该打开, 并且 crv res 最好是 5 度。 包包括:
63 lowpoly IMM crved 刷子,带和不带末端 ( ZBP )。
63 highpoly IMM crved 刷头(ZBP)。
63 个低多边形网格,3 种格式OBJ 、FBX 和 BLEND。
63 个高多边形网格,3 种格式OBJ、FBX 和 BLEND。
