画笔资源 [3D画笔] 外网自购 卡通直刘海 Hair Strands 2, IMM Curve Brush. UV Unwrapped
9531
15
价格:350元素币(或35余额) 百度网盘 销售总额:14700元素币 购买人数:42
尊敬的游客 ,本内容需要支付 350元素币十分之一的[余额] 来购买.
Zbrush Hair Strands 2 / IMM Curve Brush
Insert Multi Mesh Brush with four (4) mesh variations for creating hair strands. Single, Double, Triple, and a Double “flyer” mesh for thinner strands. The meshes have decent UVs  (center section will tile), but some stretching is unavoidable due to how the IMM brushes work. Still good enough for some basic texturing and displacements if desired.
Also including two (2) curve falloff profiles (stroke-curve modifiers). One for basic tapered strands; the other for straighter strands good for bangs and straighter hair cuts. Load the curves into the stoke>curve falloff for easy switching between them
Strands within each mesh are easily separated via ZBrush polygroup auto-grouping.
After separating into groups use the Move brush with “automasking”>”mask by polygroups“, or use move topological brush, to move the individual strands around for more variation. Perfect for for quickly creating secondary shapes and volumes from larger forms.
Smooth/ sculpt as needed. Also some good results playing with subdivisions and ‘claypolish’.
v2.0: fix to filename extensions for curve falloffs.
插入带有四 (4) 个网格变化的多网刷,用于创建发束。单、双、三和双“传单”网格,用于更细的股线。网格具有不错的 UV(中心部分将平铺),但由于 IMM 画笔的工作方式,一些拉伸是不可避免的。如果需要,对于一些基本的纹理和位移仍然足够好。
还包括两 (2) 个曲线衰减配置文件(笔划曲线修改器)。一种用于基本锥形股;另一个用于更直的股线,适合刘海和更直的剪发。将曲线加载到 stoke>curve 衰减 中,以便在它们之间轻松切换
每个网格中的股线可以通过 ZBrush 多组自动分组轻松分离。
分成组后,使用“自动蒙版”>“按多组蒙版”的移动画笔,或使用 移动拓扑 画笔,移动各个股线以获得更多变化。非常适合从较大的形状快速创建辅助形状和体积。
根据需要平滑/雕刻。还有一些使用细分和“粘土抛光”的好结果。
v2.0:修复曲线衰减的文件扩展名。
参与人数 3 元素币 +38 活跃度 +22
0anye0  发表于 2022-6-17 08:17:58
pincers  发表于 2022-6-17 09:14:47
哔咔哔咔  发表于 2022-6-17 10:09:57
感谢楼主分享
熾天之翼  发表于 2022-6-17 16:07:47
莱积  发表于 2022-6-18 19:50:16
口水怪啊  发表于 2022-6-23 10:15:08
感谢楼主分享
MJ漫步  发表于 2022-6-23 19:19:24
感谢分享~!
qq_Mr.D_o3z  发表于 2022-12-28 14:07:33
粪坑掏粪炸蛆酱  发表于 2023-1-2 00:05:29
可乐茶  发表于 2023-1-3 09:51:16
感谢楼主分享
咸鱼ycc  发表于 2023-1-3 10:12:25
黄海  发表于 2023-1-3 10:17:29
大家来给我点个赞
俞木123  发表于 2023-3-1 18:13:15
66666666666666666666666666666666666
CG毒瘤 实名
1333 小时
短杖 学徒法袍 巨浪 长剑 【绝】千人纪念徽章 长枪 火元素 黄色药水
