[材质贴图] blender 怎么将黑白图像转换成法线贴图混合器?
查看:1482 |回复:5 | 2022-6-16 23:45:51
我有这么一张图: image.png
我想把它映射成一个normal的贴图,黑色是较低的部分,白色的部分是凸起的。我尝试了这个节点图: image.png
但是它显然不起作用。如何将这样的黑白图像转换成凹凸贴图?
解决方法:
Bump from Height
...Displacement > type Bump from Height ...
Displacement > type Displacement as real geometry in render. Commonly called Micro-displacement ...
For that effect you have to under Subdivision Surface modifier enable Adaptive Subdivision than you can in material setup switch Settings > Surface > Displacement type
Normal Map
If you are really looking for Height map to Normal map convert, check this Bake Normal ...
2022-6-16 23:45:51
5个回答,把该问题分享到群,邀请大神一起回答。
这帖子重复了。不是申请删除了嘛?
2022-6-17 16:43:03   回复
2022-6-20 10:26:12   回复
谢谢分享学到了
2022-8-24 09:40:55   回复
2023-3-1 11:20:10   回复
2023-10-7 15:42:46   回复
