element3ds.com
SD-材质作品 [Tutorial] Sloppy Brick Material - Including [.SBS] & [.SBSAR] FOR FREE
12466
3
[翻译] : 在这个全新的Substance Designer教程中,你将学习如何从头到尾创建一个脏乱的砖块材质。你还将学到一些技巧,帮助你理解如何实现逼真的灰浆效果,以及类似的制作流程。教程结束时,你将对这类材质背后的技巧有深入的理解,并且会得到一个注释和可编辑的节点图,可以用来创建各种各样的脏乱砖块材料。这个50分钟的教程适合所有技能水平的人。整个过程全程讲解,分步骤进行,每个节点都会详细解释。你将获得-高清分辨率、50分钟的视频讲解-组织良好并带有注释的【.SBS】文件-包含可调整参数的【.SBSAR】文件-快速预览节点-所有依赖项现在就获取吧![video=
In this new Substance Designer tutorial, you'll learn how to create a sloppy brick material from start to finish. You'll also learn some other techniques which help you understand how to achieve the realistic mortar and also some similar workflows.
At the end of this tutorial you will have good understanding of the techniques behind creating this type of material and a graph that is commented and editable to create a wide variety of sloppy brick materials. This 50 Minutes tutorial is for all skill levels. The process is fully narrated, step-by-step & explained node-by-node, from start to finish.
WHAT YOU'LL GET
-Full HD Resolution 50 minutes narrated video.
-Well organized and commented [.SBS] File.
-[.SBSAR] File with exposed parameters.
-Quick Preview Node.
-Dependencies.
GET YOURS NOW!
https://gumroad.com/l/uZqUeQ
A站:https://www.artstation.com/abderrezakbouhedda
俊哥  发表于 2022-8-22 20:20:27
阅贴无数,楼主最强!
pincers  发表于 2022-12-6 17:16:21
qq_雾霾_hzL  发表于 2022-11-27 22:03:02
Abderrezak 实名
Material & Shader Artist (
