element3ds.com
SD-材质作品 Rippled Beach Sand - 100% Substance Designer
36424
4
[翻译] : 嗨,大家好,我再次带来了新的材质实验,这次是波纹海滩沙材质。在Substance Designer中,使用形状散射或任何基本噪点节点都很难达到这种效果。通过参考文献我发现,这明显是反应扩散现象,当沙子因为风、海浪而改变形状时会出现。这个材质是我业余时间制作的,如果有任何问题,请尽管提问,你们的支持对我来说非常重要!
Hiii guys, I'm back once again with a new material experiment, this time is a rippled beach sand material which is quite challenging to achieve its look using shape splatter or any basic noise node that's in substance designer actually. So after reading through references I've noticed that it's clearly reaction diffusion which appears when the sand takes a new shape which is happened because of the wind, shore waves...
This material I did in my free time, if you have any questions please don't hesitate to ask, your support means a lot!
参与人数 3 元素币 +27 活跃度 +18
A站:https://www.artstation.com/abderrezakbouhedda
俊哥  发表于 2022-8-23 20:06:08
楼主好人,再接再厉哦!
qq_浮云_W4z  发表于 2022-8-25 14:20:42
聊天  发表于 2022-9-13 11:44:16
FK711811  发表于 2022-9-29 14:20:39
Abderrezak 实名
Material & Shader Artist (
