价格:55 元素币
百度网盘
收益:110元素币 销量:2 提醒使用【余额支付】需要: ¥5 余额 官网链接:https://assetstore.unity.com/packages/tools/terrain/l-v-e-2019-lava-volcano-environment-2019-147383
https://youtu.be/OQrUq1s3uF0
Pack Support
- Unity 2018.3+
- Unity 2019+
- Unity 2019.1+ LW RP 5.7+;
- Unity 2019.1+ HD RP 5.7.+;
- Unity 2019.2+ LW RP 6.9+;
- Unity 2019.2+ HD RP 6.9.+;
- Unity 2019.3+ URP 7.18+;
- Unity 2019.3+ HD RP 7.18.+;
- Unity 2019.3 URP 7.2+
- Unity 2019.3 HD RP 7.2+
- Unity 2019.4 LTS HD RP
- Unity 2019.4 LTS URP
- Unity 2020+
- Unity 2020.1+ HD RP 8.2+
- Unity 2020.1+ URP 8.2+
- Unity 2020.2+ HD RP 10.2+
- Unity 2020.2+ URP 10.2+
- Unity 2020.3+ HD RP 10.3+
- Unity 2020.3+ URP 10.3+
- Unity 2020.3+ HD RP 10.7+
- Unity 2020.3+ URP 10.7+
- Unity 2021+
- Unity 2021.1+ HD RP 11.0+
- Unity 2021.1+ URP 11.0+
- Unity 2021.2+ HD RP 12.1+
- Unity 2021.2+ URP 12.1+
- Unity 2021.3+ LTS HD RP 12.1+
- Unity 2021.3+ LTS URP 12.1+
- Unity 2022
- Unity 2022.1+ HD RP 13.1+
- Unity 2022.1+ URP 13.1+
- RTX support for unity 2020 HD RP
- VS PRO Instanced Indirect support for HD and URP 7.2+ and Unity Standard
- DOTS and SRP batcher support for unity 2019.3+ at HD, URP;
- New unity terrain support Unity 2018.3+;
- New RAM 2019;
- For lower engine versions please use our old
L.V.E - Lava & Volcano Environment
To run HD or URP, LW RP please import pack to HD or URP project and then import support pack which is inside the asset in "HD and URP Support Packs" folder. It will replace shaders, prefabs, meshes so they will work with RP out of the box. Please also check readme files inside that folder.
L.V.E 2019– Lava and Volcano Environment 2019 is new rebuild and extended version of L.V.E. It is big pack of environment, systems, tools, textures, particles, post processing stacks and models which give you the ability to create volcanos, caves, interiors, rivers in high quality result and very cheap in render setup. Our spline and vertex paint tools which are included in this pack will support many very advanced systems/arts. Simulation tool give you ability to create lava river which is accurate to terrain shape via 3 mause clicks. You simply set first point and click simulate. Physics scripts give you ability to flow objects on lava surface and heat at realtime. You also could heat static objects which touch lava out of the box via our shader and script. Rocks and textures in this packs could also be used as asteroids, or normal environment. All assets, post processing, demos from video are included in the pack. Tutorial scene will help you to get full info about features. Pack co-work with our river water systems - R.A.M 2019. One spline and system to rule them all! Just play with it!
PACK FEATURES:
# 1 Spline tool:
- create very advanced connected lava river networks (lakes,rivers,);
- automatic flowmap with noises;
- customize your lava river / lake via vertex paint;
- customize / overwrite automatic river /lake flow map by painter and change it’s direction and speed;
- physics simulation for objects that flow on lava sruface;
- automatic heating for objects that flow or touch lava surface;
-simulate lava river tool, setup 1 point and L.V.E will analise space to create lava river;
- scale, move, rotate any lava river point;
- snap / unsap into the terrain or models in all or separated points;
- change spline shape per point or in all points to create best looking road or river;
- change triangle amount and distribut them in spline space to get cheaper and best looking spline;
- create fabulous lava river with: waterfalls, slow, fast, lake,;
- rotate, invert uv to make compatibility with every texture direction;
- profile system - save your lava setup and switch to other in 2 seconds;
- automatic river network refreshing system to avoid river connections problems;
- place your lava river or cliff border with few seconds and blend it with terrain via vertex color;
- debug your flow map / normal / vertex colors with advanced debug shader to get best and clear result;
- shape, paint and foliage remove system for unity terrain;
- automatic stone heating function;
- R.A.M 2019 compatibility;
- API;
- CSV points import panel;
- Vegetation Studio support;
- Vegetation Studio PRO support;
- Streaming friendly - cut your river into submeshes or splines;
- HD and URP, LW RP support;
- Multiple Terrains support;
# 2 Shader and material features :
- cheap in render;
- 16 shaders and variants to fit scene performance and visual aspect;
- special mobile shaders;
- vertex paint tool;
- tessellation support;
- flow map support;
- vertex color support;
- rim light support;
- special shader for frozen lava;
- up to 3 different lava layers support;
- standard lava material in specular, metallic versions and vertex paint support for models;
- uv free materials for cliffs/interior walls with terrain blending;
- smoke and spark particle shaders;
- heated / distorted air particle shader;
- lava river shaders could rotate UV from U/-U into V/-V directions;
- shaders works on linear and gamma rendering (you only need to color and emission intensivity for gamma);
- cutout shaders versons for models;
# 3 Artistic content:
- 99 (14 sets) Top and HQ ground and lava river textures (Albedo, Normal, AO, Height,Emission);
- 39 (14sets) rock and cliffs atlased textures (Albedo, Normal, AO, Height,Emission);
- 40 rock prefabs (20 models);
- 18 cliff prefabs (9 models);
- 11 particle prefabs, even volcano explosion with emissed rocks.;
- 2 cts profile file to get terrain height blend result by 1 click;
- 3 demo scenes from video;
- tutorial/ know how demo scene;
- post proces stack for each scene;
# 4 Additional tools content:
- vertex and flowmap painter on meshes;
- physics scripts to make your rocks flow and burn when they hit lava;
- automatic heating scripts when rock heat the lava;
FORUM LINK
Check also our R.A.M - River Auto Material which is based at same spline technology. Links are below.
Feel free to contact and visit us at: Discord Channel
You could also look at our other packs:
Assets Bundle:
Environment Bundle - Dynamic Nature
Unity Tools:
River Auto Material 2019
River Auto Material
Lava & Volcano Environment 2019
World Streamer 2
World Streamer
Terrain Stitcher Tools
Multiple Terrain Brush
Environment:
Mountain Environment - Dynamic Nature
Forest Environment - Dynamic Nature
Meadow Environment - Dynamic Nature
Mountain Trees - Dynamic Nature
Fire & Smoke - Dynamic Nature
Dynamic Nature - Starter
Ice World
Advanced Rock Pack
Advanced Foliage Pack
PBR Graveyard Pack
Winter Mountains and Stamps
Photo Scanned Park Assets
Mountain Tree Pack
Realistic Tree Pack
Realistic Grass Pack
Ground Textures:
Winter Ground Pack
Landscape Ground Pack
Landscape Ground Pack 2
VR & FP Models:
VR Hands FP Arms
Asset created in co-op with
IndagoVR
IMPORTANT:
Pack contain Triangle.NET library under MIT Licence check licenseTriangleNet.json file in package for details.
包支持
- Unity 2018.3+
- Unity 2019+
- Unity 2020+
- Unity 20220.2+ HD RP 10 +
- Unity 2020.3+ 高清 RP 10.3+
- Unity 2020.3+ HD RP 10.7+ - Unity 2020.3+
URP 10.7+ - Unity
2021+
- Unity 2022
- RTX 支持 unity 2020 HD RP
- VS PRO 实例化间接支持 HD和 URP 7.2+ 和 Unity 标准
- DOTS 和 SRP 批处理器支持 HD,URP 的统一 2019.3+;
- 新的统一地形支持 Unity 2018.3+;
- 新内存 2019;
- 对于较低的引擎版本,请使用我们的旧版本
LVE - Lava & Volcano Environment
要运行 HD 或 URP,LW RP请将包导入 HD 或 URP 项目,然后导入“HD and URP Support Packs”文件夹中资产内的支持包。它将替换着色器、预制件、网格,以便它们可以与 RP 一起使用。还请检查该文件夹中的自述文件。
LVE 2019 – Lava and Volcano Environment 2019 是 LVE 的新重建和扩展版本它是环境、系统、工具、纹理、粒子、后处理堆栈和模型的大包,使您能够创建火山、洞穴、内部、河流高质量的结果和非常便宜的渲染设置。此包中包含的我们的样条线和顶点绘制工具将支持许多非常先进的系统/艺术。模拟工具使您能够通过 3 次鼠标点击创建与地形形状准确的熔岩河。您只需设置第一个点并单击模拟。物理脚本使您能够在熔岩表面流动物体并实时加热。您还可以通过我们的着色器和脚本加热接触熔岩的静态对象。这个包中的岩石和纹理也可以用作小行星或正常环境。包中包含所有资产、后期处理、视频演示。教程场景将帮助您获得有关功能的完整信息。打包与我们的合作 河水系统-RAM 2019。一个样条和系统来统治它们!只是玩它!
包特点:
# 1 样条工具:
- 创建非常先进的连接熔岩河网络(湖泊、河流);
- 带有噪音的自动流程图;
- 通过顶点绘制自定义您的熔岩河/湖;
- 由画家自定义/覆盖自动河流/湖泊流量图并更改其方向和速度;
- 在熔岩表面流动的物体的物理模拟;
- 对流动或接触熔岩表面的物体进行自动加热;
-模拟熔岩河工具,设置1个点,LVE将分析空间以创建熔岩河;
- 缩放、移动、旋转任何熔岩河点;
- 在所有点或分开的点中捕捉/解开地形或模型;
- 更改每个点或所有点​​的样条形状以创建最佳外观的道路或河流;
- 改变三角形数量并将它们分布在样条空间中以获得更便宜和最好看的样条;
- 创建神话般的熔岩河:瀑布,慢,快,湖,;
- 旋转、反转 uv 以兼容每个纹理方向;
- 配置文件系统 - 保存您的熔岩设置并在 2 秒内切换到其他设置;
- 自动河网刷新系统,避免河流连接问题;
- 在几秒钟内放置您的熔岩河或悬崖边界,并通过顶点颜色将其与地形融合;
- 使用高级调试着色器调试您的流程图/法线/顶点颜色以获得最佳和清晰的结果;
- 统一地形的形状、油漆和树叶去除系统;
- 石材自动加热功能;
- RAM 2019 兼容性;
- API;
- CSV点导入面板;
- 植被工作室支持;
- Vegetation Studio PRO 支持;
- 流媒体友好 - 将您的河流切割成子网格或样条线;
- HD和URP,LW RP支持;
- 多地形支持;
# 2 着色器和材质特性:
- 渲染成本低;
- 16 种着色器和变体,以适应场景性能和视觉方面;
- 特殊的移动着色器;
- 顶点绘制工具;
- 镶嵌支持;
- 流程图支持;
- 顶点颜色支持;
- 边缘灯支持;
- 冻结熔岩的特殊着色器;
- 最多支持 3 个不同的熔岩层;
- 镜面反射、金属版本的标准熔岩材料和模型的顶点绘制支持;
- 具有地形融合的悬崖/内墙的无紫外线材料;
- 烟雾和火花粒子着色器;
- 加热/扭曲空气粒子着色器;
- 熔岩河着色器可以将 UV 从 U/-U 旋转到 V/-V 方向;
- 着色器适用于线性和伽马渲染(您只需要为伽马着色和发射强度);
- 模型的抠图着色器版本;
# 3 艺术内容:
- 99(14 套)顶部和 HQ 地面和熔岩河纹理(Albedo、Normal、AO、Height、Emission);
- 39(14 套)岩石和悬崖贴图纹理(Albedo、Normal、AO、Height、Emission);
- 40 个岩石预制件(20 个模型);
- 18 个悬崖预制件(9 个模型);
- 11 种粒子预制件,甚至火山爆发与发射的岩石。
- 2 cts 配置文件,一键获取地形高度混合结果;
- 来自视频的 3 个演示场景;
- 教程/了解演示场景;
- 每个场景的后处理堆栈;
# 4 附加工具内容:
- 网格上的顶点和流图画家;
- 物理脚本让你的岩石在撞击熔岩时流动和燃烧;
- 岩石加热熔岩时的自动加热脚本;论坛链接
还要检查我们的 RAM - River Auto Material,它基于相同的样条技术。链接如下。
请随时联系并访问我们: Discord Channel您还可以查看我们的其他包:资产包:环境包 - 动态自然Unity 工具:River Auto Material 2019 River Auto Material Lava & Volcano Environment 2019 Lava & Volcano Environment World Streamer 2 World Streamer Terrain Stitcher Tools多地形画笔环境:山地环境 - 动态自然森林环境 - 动态自然草甸环境 - 动态自然山地树木 - 动态自然
Fire & Smoke - Dynamic Nature Dynamic Nature - Starter Ice World Advanced Rock Pack Advanced Foliage Pack PBR Graveyard Pack Winter Mountains and Stamps Photo Scanned Park Assets Mountain Tree Pack Realistic Tree Pack真实草包Ground Textures: Winter Ground Pack Landscape Ground Pack Landscape Ground Pack 2 VR & FP 模型:与IndagoVR 合作创建的VR Hands FP Arms Asset 重要提示: 包包含 MIT 许可证下的 Triangle.NET 库,请检查包中的 licenseTriangleNet.json 文件以获取详细信息。
