程序化贴图 [sbs格式] 外网自购 Substance Designer-Signed Distance Fields Vol.1
1243
8
价格:300元素币(或30余额) 百度网盘 销售总额:1500元素币 购买人数:5
尊敬的游客 ,本内容需要支付 300元素币十分之一的[余额] 来购买.
About
Signed Distance Functions (SDF), return the shortest distance between a point and an implicit curve (or surface when working in 3D space). The sign of the distance indicates whether the point falls inside or outside the curve.
The collection of nodes for Substance Designer (v.2021.2.x) in this bundle allow to easily create and manipulate SDF in order to create virtually any 2D shape. These SDF nodes have multiple advantages over \'traditional\' shape nodes in Substance Designer, notably the fact that they allow smooth blending between shapes, the ability to easily anti-alias them and the ability to generate very clean normals from the result. This makes them very powerful, and ideal for \"height map modeling\". Includes Source Files
Contents
1. Shape Nodes
This package contains 16 SDF Shape nodes that output a Signed Distance Field, all with custom parameters to control the way they look. They range from simple geometric shapes (circle, rectangle, triangles, regular polygons, etc.) to more complex shapes (bezier curve, vesica, cross, etc.).
  • Circle
  • Line
  • Rectangle
  • Rhombus
  • Equilateral Triangle
  • Isoceles Triangle
  • Triangle
  • Uneven Capsule
  • Pentagon
  • Hexagon
  • Octogon
  • Isoceles Trapezoid
  • Ellipse
  • Vesica
  • Cross
  • Bezier (Quadratic)
2. SDF Tools Nodes
In order to really get the most out of the SDF Shape nodes, this bundle also contains a set of nodes used to draw,  combine, visualize and transform SDF.
SDF Draw
Typically this node would be placed at the end of a series of SDF nodes in order to render it out as a grayscale shape.
SDF Combine
In order to create more complex shapes, this node offers different options to combine SDF together, as well as different transitions between distance fields.
Operations:
  • Union (A ⋃ B)
  • Subtraction (A – B)
  • Intersection (A ⋂ B)
  • Interpolate (A → B)
Transitions:
  • No Transition
  • Chamfer
  • Smooth
  • Steps
SDF Transform
This node allows to modify an input SDF in multiple different ways create even more interesting effects.
  • Push, Offset and “Annularize”
  • Offset and Rotation
  • Wobble Effect
SDF Visualize
This node is also used to visualize a SDF, but unlike the SDF Draw node, it is mostly useful in order to “debug” a SDF as it give more information about it (inside/outside, distance “steps”, etc.). It is also possible to use this node creatively and generate some nice effects !
Release Notes
  • SDF Ellipse : Updated the node with a new method (The old method was causing artifacts when width or height had a value of 0)
  • SDF Bezier : Fixed a floating point precision issue sometimes causing artifacts when all points were almost aligned
  • SDF Vesica : Fixed an issue when using a non-square resolution
  • SDF Rectangle : Added a Corner Radius Parameter
  • SDF Pentagon, SDF Hexagon and SDF Octogon: Added a Roundness Parameter
  • SDF Combine : Added 2 new Transition options (Round and Steps)
  • SDF Visualizer : Added an additionnal color scheme
  • Rotation : Fixed an issue when rotating SDFs with a non-square resolution (Shape nodes and Transform node)
  • Added additional options on multiple SDF nodes to pick the Origin (pivot) of the shape
  • Changed \"soft\" range of the Offset parameter on multiple nodes
  • Replaced the Preview Mode (Toggle) on SDF nodes with a separate output
  • Updated some node icons to improve readability
  • Updated the Description, Category and Tags on some nodes
  • Minor fixes
关于有
符号距离函数(SDF),返回点与隐式曲线(或在 3D 空间中工作时的曲面)之间的最短距离。距离的符号表示该点是落在曲线里面还是外部。
此捆绑包中的Substance Designer  (v.2021.2.x)节点 集合允许轻松创建和操作 SDF,以创建几乎任何 2D 形状。与 Substance Designer 中的“传统”形状节点相比,这些 SDF 节点具有多种优势,特别是它们允许形状之间的平滑混合、轻松消除锯齿的能力以及从结果中生成非常干净的法线的能力。这使得它们非常强大,非常适合“高度图建模”。
内容
1.形状节点
这个包包含16 个 SDF 形状节点,它们输出一个有符号距离场,所有这些节点都带有自定义参数来控制它们的外观。它们的范围从简单的几何形状(圆形、矩形、三角形、正多边形等)到更复杂的形状(贝塞尔曲线、vesica、十字形等)。
为了创建更复杂的形状,该节点提供了将 SDF 组合在一起的不同选项,以及距离场之间的不同过渡。
操作:
联合 (A ⋃ B)
减法(A - B)
交叉口 (A ⋂ B)
插值 (A → B)
过渡:
无过渡
倒角
光滑的
脚步
SDF 变换
此节点允许以多种不同方式修改输入 SDF,从而创建更有趣的效果。
推动、偏移和“环形化”
偏移和旋转
摆动效果
SDF Visualize
此节点也用于可视化 SDF,但与 SDF Draw 节点不同,它主要用于“调试” SDF,因为它提供了有关它的更多信息(里面/外部、距离“步数”等。 )。也可以创造性地使用这个节点并产生一些漂亮的效果!
参与人数 9 元素币 +66 活跃度 +27
n008  发表于 2023-3-1 23:45:02
非常棒
qq_Sam_z6z  发表于 2023-4-10 11:59:54
jaegerleecoutre  发表于 2023-4-10 16:35:34
666666666666666666666
狂奔de蜗牛  发表于 2023-4-10 20:12:56
mimilqlq  发表于 2023-4-11 15:33:59
7777777777777
夏妆-  发表于 2023-4-12 17:52:32
感谢楼主分享
阿恺动次 实名
20 小时
长剑 长枪
