[Unity] GPT,帮我写个Unity的GPU Instancing的车换色特效
查看:16297 |回复:8 | 2023-3-20 10:09:24
让我看看你有多牛逼
2023-3-20 10:09:24
 赞 赞 3
8个回答,把该问题分享到群,邀请大神一起回答。
Sure, I can definitely help you with that! First, let me explain what GPU Instancing is. It\'s a rendering technique that allows Unity to draw many of the same mesh with a single draw call, which improves performance.
To create a color-changing effect using GPU Instancing, we first need to set up the instancing properly. This involves creating a Material that supports instancing and enabling it in the Shader properties.
Once we have the instancing set up, we can use a script to modify the color of the instanced objects. The script would iterate through each instance and change its color based on some criteria, such as a timer or user input.
Here\'s some example code to get you started:
```csharp
using UnityEngine;
public class ColorChanger : MonoBehaviour
    public Material material; // The instanced material
    public float speed = 1f; // The rate at which the colors change
    private MaterialPropertyBlock propBlock; // Used to set per-instance properties
    private float t = 0f; // Current time
    private void Start()
        propBlock = new MaterialPropertyBlock();
    private void Update()
        t += Time.deltaTime;
        // Iterate through all instances of the material
        for (int i = 0; i < material.instanceCount; i++)
            // Set a random color for each instance
            Color color = new Color(Random.value, Random.value, Random.value);
            // Set the color in the per-instance property block
            propBlock.SetColor(\"_Color\", color);
            // Apply the property block to the current instance
            Graphics.DrawMeshInstanced(
                material.GetMesh(),
                i,
                material,
                transform.position,
                transform.rotation,
                propBlock
This script will randomly change the color of each instance of the material every frame. You could modify it to use a timer or user input instead, depending on your needs.
I hope this helps! Let me know if you have any questions.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
Pharmacist : How does unity change hundreds of millions of model rotations in GPU Instancing
2023-3-20 10:17 回复
2023-3-20 10:09:46   回复
 赞 赞 5
2023-3-21 01:34:17   回复
 赞 赞 3
2023-4-4 00:57:26   回复
 赞 赞 4
2023-4-4 00:57:29   回复
 赞 赞 3
2023-4-4 00:57:33   回复
 赞 赞 4
2023-4-10 15:15:29   回复
 赞 赞 2
以后GPT就是所有程序的小助手了
2023-4-15 11:01:23   回复
 赞 赞 2
老哥可以的
2023-5-11 10:42:55   回复
 赞 赞 2
