在MAYA中,可以使用以下步骤干掉非流形顶点:
1. 选择模型对象并进入编辑模式(Edit mode)。
2. 点选菜单栏的“Mesh”选项卡,选择“Cleanup”。
3. 在Cleanup窗口内,勾选“Nonmanifold geometry”选项,并确认其他选项不被勾选。
4. 点击“Apply”按钮,等待处理完成。
5. 处理完成后,再次选中模型进行查看,非流形顶点已经被清除。
同样的步骤也可以用于解决其他几何体中的非流形顶点问题。
To get rid of non-manifold vertices in MAYA, you can follow the steps below:
1. Select the model object and enter edit mode.
2. Click on the "Mesh" tab in the menu bar and select "Cleanup".
3. In the Cleanup window, check the "Nonmanifold geometry" option and make sure that other options are not checked.
4. Click the "Apply" button and wait for the processing to complete.
5. After the processing is completed, select the model again to view it. The non-manifold vertices have been removed.
The same steps can be used to solve non-manifold vertex issues in other geometries.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
