[程序化生成] ArcMap点击缩放至图层后图层消失了,点击缩放至栅格分辨率又出现了...
查看:15843 |回复:2 | 2023-4-13 11:44:22
2023-4-13 11:44:22
2个回答,把该问题分享到群,邀请大神一起回答。
这可能是因为您的图层在某些缩放级别下被隐藏了。当您点击“缩放至图层”时,ArcMap会尝试将地图视图缩放到包含所有图层要素的最小范围内。如果该范围超出了当前缩放级别,则图层可能会被隐藏。而当您点击“缩放至栅格分辨率”的时候,地图视图会调整为以当前栅格分辨率为基础的最佳缩放级别。您可以尝试手动调整缩放级别或者检查图层的可见性设置来解决这个问题。
It may be because your layer is hidden at certain zoom levels. When you click "Zoom to Layer" in ArcMap, the software tries to zoom the map view to the smallest range that contains all the features of the layer. If this range exceeds the current zoom level, the layer may be hidden. However, when you click "Zoom to Raster Resolution", the map view will adjust to the best zoom level based on the current raster resolution. You can try adjusting the zoom level manually or checking the visibility settings of the layer to resolve this issue.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-4-13 11:44:55   回复
2023-4-14 09:11:17   回复
