Crystal wand requires a certain amount of contribution points to be used. If your contribution points are not high enough, you cannot use the crystal wand. Usually, at least 200 contribution points are required to use the crystal wand. It is recommended that you continue to work hard to increase your contribution points so that you can use more items and features.
