要提升元素等级,首先需要消耗对应元素的资源进行升级。这些资源可以通过完成任务、挑战和购买获得。此外,角色的等级和突破次数也会影响元素等级的上限。
元素等级受到角色等级和突破次数的影响,同时还受到元素精通属性的影响。所以,如果你的元素等级降低了,可能是因为你的角色等级或突破次数下降了,或者你的元素精通属性有所减少。
To increase the elemental level, you need to consume corresponding elemental resources for upgrading. These resources can be obtained through completing tasks, challenges, and purchases. In addition, the character's level and breakthrough times also affect the upper limit of the elemental level.
The elemental level is affected by the character's level and breakthrough times, as well as the elemental mastery attribute. Therefore, if your elemental level has decreased, it may be because your character's level or breakthrough times have decreased, or your elemental mastery attribute has decreased.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
