在MAYA中,可以在菜单栏上选择“Windows” -> “Settings/Preferences” -> “Preferences”,然后选择“Settings”选项卡,在“Working Units”区域可以设置单位为毫米、厘米、米等。
In MAYA, you can go to \"Windows\" -> \"Settings/Preferences\" -> \"Preferences\" in the menu bar, then choose the \"Settings\" tab. In the \"Working Units\" section, you can set the unit to millimeters, centimeters, meters, etc.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
