[软件问题] ZB这个软件主要是吃内存吗?
查看:15744 |回复:1 | 2023-6-9 08:38:43
32G内存ZB保存文件有点慢,重布线和拓补也慢,换64G内存是不是要好些?
2023-6-9 08:38:43
1个回答,把该问题分享到群,邀请大神一起回答。
ZB这个软件相对于其他软件来说会占用较多的内存资源,因此使用ZB时确实会比较吃内存。如果保存文件、重布线和拓扑等操作比较慢,可以考虑增加内存条的容量,比如升级到64G内存,这样可以提高计算机的性能,操作起来也会更流畅。
ZB software mainly consumes memory resources compared to other software. Therefore, using ZB software will indeed require more memory. If saving files, rewiring and topology operations are slow, it is recommended to consider increasing the capacity of the memory module, such as upgrading to 64G memory. This can improve the performance of the computer, and make the operation smoother.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
liubing129 : 刚换了阿斯加特弗雷的32Gx2内存,用ZB的确流畅了很多
2023-6-10 08:51 回复
2023-6-9 08:38:53   回复
 赞 赞 2
