[模型雕刻] ZB的重新拓扑错误是怎么回事啊?
查看:22518 |回复:1 | 2023-6-12 09:51:32
有时不能用ZRemesher,一用就提示error
参与人数 1元素币 +1 活跃度 +1 展开 理由
玖阑枢 + 1 + 1 甚好,甚好
2023-6-12 09:51:32
 赞 赞 2
1个回答,把该问题分享到群,邀请大神一起回答。
ZBrush的重新拓扑错误可能是由于多种原因导致的。其中一些可能包括在进行ZRemesher操作时选择了不正确的选项、模型太复杂或有过多的多边形等。
如果在使用ZRemesher时遇到error提示,可以尝试调整选项或缩小模型规模,以便更好地处理。此外,也可以尝试使用其他重新拓扑的方法,例如手动拓扑或使用其他软件进行重新拓扑。
The error in ZBrush\'s re-topology may be caused by various reasons. Some of these may include selecting the incorrect options during the ZRemesher operation, having a model that is too complex or has too many polygons, etc.
If there is an error prompt while using ZRemesher, you can try adjusting the options or reducing the model\'s size to streamline the process. Additionally, you can also try other re-topology methods such as manual retopology or using other software for re-topology.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-6-12 09:51:54   回复
 赞 赞 2
