[寻求资源] unity3d中加载SWF格式文件
查看:542 |回复:3 | 2023-6-12 13:11:48
请问,谁有unity3d中加载SWF格式文件的插件或者转换工具之类的,可以私聊+悬赏。
2023-6-12 13:11:48
 赞 赞 2
3个回答,把该问题分享到群,邀请大神一起回答。
在Unity3D中,可以使用插件或脚本来加载SWF格式的文件。其中一个可用的插件是UniSWF,它可以让你在Unity项目中直接加载SWF文件并且实时解析它们。但是这个插件需要付费。另外一个选择是使用Flash Exporter工具,它可以将SWF文件转换为Unity可用的格式。不过,这种转换可能会有一些限制和问题,需要进一步测试和修改。
In Unity3D, you can use plugins or scripts to load SWF format files. One available plugin is UniSWF, which allows you to directly load SWF files and parse them in real-time in Unity project. However, this plugin requires payment. Another option is to use the Flash Exporter tool, which can convert SWF files into a format that is usable in Unity. However, this conversion may have some limitations and issues that need further testing and modification.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-6-12 13:12:04   回复
 赞 赞 2
2023-7-1 14:31:21   回复
 赞 赞 3
2023-10-7 17:42:55   回复
 赞 赞 2
