Yes, you can customize the view operation shortcuts in 3ds Max. You can follow these steps:
1. Open the 3ds Max software.
2. Click on the "Customize" option in the menu bar.
3. Select the "Customize User Interface" option from the drop-down menu.
4. In the "Customize User Interface" dialog box, go to the "Keyboard" tab.
5. In the list on the right, you can find various view operation commands such as "Zoom In," "Zoom Out," "Pan," etc.
6. Find the command for which you want to change the shortcut key and select the corresponding shortcut key (if any) in the "Assigned" column.
7. In the "Change Selected Key (Path and Button)" box at the bottom, click the "Assign" button.
8. Enter your desired new shortcut key, such as "Ctrl + Q" to replace the default shortcut key.
9. Click the "OK" button to save the changes and close the dialog box.
Now you can use your customized shortcut keys to perform the corresponding view operations. Note that if you want to restore the default shortcut keys, simply find the corresponding command in step 6 and click the "Clear All" button.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
