element3ds.com
3D角色_武器_装备 [科幻机械] Bodeo 1889 - ordinanza italiano
33025
2
[翻译] : 冬天来了,所以我又有了一件小资产可以展示。我一直想在某个时候制作一把具有功能性内部结构的正统左轮手枪。再加上《伊松佐》的发布,加上耳朵里听太多的埃罗·拉马佐蒂(Eros Ramazzotti)歌曲,于是,博迪奥1899应运而生。-博迪奥Mod. 1889自1891年被采用以来,一直是意大利军队的标准服务左轮手枪,并在第一次世界大战和第二次世界大战期间使用。它是一款使用大口径10.35mm意大利标准弹药的门式装填左轮手枪。作为一种安全措施,装填门与击锤相连,打开装填门会断开击锤。之后拉动扳机只会转动转轮,使得新的弹药快速上膛。总的来说,这是一个相对简单的机制,移动部件很少。这有助于左轮手枪在整个漫长服役期的可靠性和可维修性。-左轮手枪有几种版本,主要分为士兵型(意大利da truppa,也称为Type A,tipo A)和军官型(意大利da ufficiali,也称为Type B,tipo B)。稍后还存在一种类似于Tipo B的轻量化(allegerito)变体。这款模型包含了所有这些版本,不同部分是模块化的,可以互换。这样,只需一个道具,就可以实现所有变种。-这次我将项目完全保留在Blender中,利用广为人知的Remesh Corrective Smooth流程处理大型部件,传统的子级D网格在合适的地方使用,特别是在较小部件上。模型设置了一个额外的1K纹理集,包含了握把和任何理论上在游戏中会添加到枪支上的进一步定制皮肤几何体。-Pizza BigBoss Pancho(https://skfb.ly/o7YYy)由ponomarovmax授权,根据Creative Commons Attribution许可(https://creativecommons.org/licenses/by/4.0/)。-模型规格-博迪奥1889 LOD0(轻量型):23,492个/(士兵型)23,291个/(军官型)23,789个2x2048x2048像素(可交换部分,静态部分分开)1x1024x1024像素(握把和皮肤扩展)104.7像素/厘米-弹壳LOD0(完整):850个/(已发射)652个512x512像素129.9像素/厘米(比其他部分的平均值稍高,以便更清楚地看到诱人的弹头印记)
Winter is coming  and thus I have another little asset to showcase. Ive always wanted to make a proper revolver with functioning internals at some point. Combine that with the release of Isonzo, plus way too much Eros Ramazzotti in the ears  and voilà, the Bodeo 1899 has been realized. -The Bodeo Mod. 1889 served as the standard service revolver for the Italian Army after its adoption in 1891 and saw usage during the First World War aswell as during World War II. It is a gate-loading revolver using the large caliber 10.35mm Ordinanza Italiana cartridge. As a safety measure, the loading gate is connected to the hammer, and opening the loading gate disconnects the hammer. Pulling the trigger after that will only turn the cylinder and allows for relatively fast chambering of new cartridges. All in all, its a relatively simple mechanism with few moving parts. This helped with reliability and repairability over the entirety of the revolvers very long service life.-A few versions of the revolver exist, with two major ones the Enlisted or Trooper type (Italian da truppa, also known as Type A, tipo A)  with a collapsible trigger assembly, and the Officer type (Italian da ufficiali, also known as Type B, tipo B).  A third variant similar to the Tipo B  the allegerito (lightened) variant  also existed later down the line. This model has them all, with differing parts being modular and interchangable. This way, all variants can be achieved with one prop.-I kept the project entirely within Blender this time, utilizing the all-well-known Remesh  Corrective Smooth workflow for bigger pieces, and traditional sub-D where it made sense, especially with smaller parts. The model is setup with an additional 1k texture set, which houses the grips and any further custom skin geometry that would be added to the gun in its theoretical in-engine implementation.-Pizza BigBoss Pancho (https//skfb.ly/o7YYy) by ponomarovmax is licensed under Creative Commons Attribution (http//creativecommons.org/licenses/by/4.0/).-Model Specifications-Bodeo 1889 LOD0 (tipo allegerito) 23,492 /  (tipo A) 23,291 /  (tipo B) 23,789   2x2048x2048px (exchangable parts  static parts separate)1x1024x1024px (grips and skin addons)                  104.7 px/cm-Cartridge LOD0     (full) 850 /  (spent) 652   512x512px   129.9 px/cm (a bit higher average than the rest, just so you can see that juicy headstamp more clearly)
参与人数 1 元素币 +10 活跃度 +5
Artstation:https://www.artstation.com/roartal/albums/all
qq_醉红尘_Fsz  发表于 2025-5-27 12:58:54
风云  发表于 2025-5-29 19:43:32
Markus_K 实名
3D艺术家
