element3ds.com
3D物件_场景_载具 [欧美写实] Project NSX-E
33117
[翻译] : NSX-E项目是对东京警视厅退役NSX警车进行改装的探索。这些车辆配备了电动动力系统,包括每个轮子一个电机,新的磁悬浮悬挂和扭矩向量驱动模块。原来的V6 VTEC单元已被移除,现在用于容纳电子驱动列车的电池供应,这被放置得非常理想,实现了接近50:50的重量分配,并降低了车辆的重心。第一代改装的追捕车车队将重新部署在东京警视厅。模型使用Blender创建,渲染使用Cycles,材质工作在Painter/Megascans上,后期合成在Photoshop CC中完成。欢迎光临。
Project NSX-E, is an exploration of retrofitting the redundant fleet of NSX police vehicles at the Tokyo PD. These have been retrofitted with electric power trains which consist of 4 motors, one at each wheel, new mag ride suspension and torque vectoring drive modules. The original V6 VTEC unit has been removed and now houses the electronic drive trains battery supply, this is situated perfectly in the vehicle giving it closer to ideal 50/50 weight distribution and lowering the centre of gravity with in the vehicle. The MK1 retrofitted pursuit vehicle fleet will be re-deployed with in the Tokyo PD.Modelled in Blender, Rendered in Cycles Material work Painter/Megascans Compositing in PhotoshopCC Welcome.
参与人数 1 元素币 +3 活跃度 +1
Artstation:https://www.artstation.com/benarmstrongart
Ben_Armstrong 实名
资深环境美术师
