UE虚幻资源 [蓝图资源] ue4藤蔓蓝图 虚幻4智能样条线 Smart Spline Generator
194
12
引擎插件类型
软件版本要求: 未知最低软件版本限制
引擎插件类型: 模型|贴图
Preview: youtube.com/watch?v=bvrKHUgBYKc
This tool allows to generate various assets that automatically align/react to any surface, in highly customizable way. Create ivy, vine, ropes, bridges, fences and more – with many customizable parameters & possibility to use your own meshes.
• Fast and easy generation of surface-aligning assets
• Many parameters for controlling generation behavior, all described in their tooltips and in documentation levels
• In-engine documentation: All the features explained on working examples in demo levels
• Possibility to use your own meshes
• Set of starting presets included
• With help of UE Merge tool, you can convert any generated asset into static mesh, to reuse it in different levels/projects – or to export & edit it in your 3D package!
• Made 100% in Blueprints.
技术细节
Number of blueprints: 24 (1 main generator blueprint & 23 default presets)
List of features:
• Large set of generation parameters, like spline direction, sub-spline amount, spline/sub-spline length, curve, mesh amount, align rotation, height above ground, random irregularity levels and many, many more…
• Automatic bridge mechanic: Automatically finds nearby surfaces to make bridges with. Allows to control bridge gravity and more (presented in the video)
• Low-poly edge snapping: Allows to generate lower-poly assets without problems caused by low poly count near surface edges (presented in the video)
• Automatic spline mesh optimization – replaces most of spline mesh sections with low-poly versions, leaving only critical areas like edges or corners
• Compatible with UE Merge Actors tool, which allows to convert any generated asset into a single static mesh
• Many starting default presets that you can derive from.
Intended Platforms: All
Platforms Tested: Windows
Documentation Included: Yes (all features explained on working examples in demo levels)
技术细节
List of features:
下载仅供学习查看,请下载后24小时删除,请前往官网下载。
参与人数 3 元素币 +27 活跃度 +10
笑果兔  发表于 2023-7-7 15:43:45
厉害了
KONOSUBA  发表于 2023-7-10 15:54:12
Poison~  发表于 2023-8-3 13:56:28
看,那只丘~  发表于 2023-8-15 14:30:03
小花猫  发表于 2023-9-14 17:46:49
看看
lninser  发表于 2023-10-15 09:52:00
1
lh1031464180  发表于 2023-10-16 11:40:12
22222222222222
niaorenkk  发表于 2023-11-6 17:19:57
的萨拉可是大家发链接洒到了飞洒地方
卡西莫多的礼物  发表于 2023-11-27 16:59:35
0.0
小灰  发表于 2024-6-16 16:36:41
11
灵魂独舞  发表于 2024-6-16 22:11:13
好东西,看看先
灵魂独舞  发表于 2024-6-16 22:12:14
先先先
奶油桃子 实名
1728 小时
黄色药水 铁剑 长剑 长枪 火元素
