element3ds.com
3D角色_武器_装备 [欧美写实] HF Industrial Greatsword
33414
43
[翻译] : 个人作品,为Alex Senechal在Discord上发起的近战武器设计挑战。这是一款大剑/巨切刀,能够执行高频锯割动作(类似拉锯),以增强切割能力。它还可以安装边缘加固,使其变成笨重但极具破坏力的钝器。边缘加固可以通过引爆分布在上面的爆炸螺栓在使用中卸下。
Personal work for Alex Senechals Melee weapon design challenge on his discord its a  Greatsword/Giant Cleaver which can perform a high frequency sawing movement (like a pull saw) to increase its cutting power. It can also be installed with edge bracing which turns it into a cumbersome but devastating blunt weapon. The edge bracing can be dropped mid-use by detonating the explosive bolts lined up on them
参与人数 1 元素币 +4 活跃度 +1
A站:https://www.artstation.com/creditian
qq_醉红尘_Fsz  发表于 2025-3-24 14:48:56
Creditian 实名
Concept Artist - AVAILABLE, cr
