element3ds.com
SD-材质作品 [Tutorial] Sloppy Brick Material - Including [.SBS] & [.SBSAR] FOR FREE
33507
[翻译] : 在这个全新的Substance Designer教程中,你将学习如何从头到尾创建一个脏乱的砖块材质。你还将学到一些技巧,帮助你理解如何实现逼真的灰浆效果,以及类似的制作流程。教程结束时,你将对这类材质的制作技术有深入的理解,并获得一个注释和可编辑的图表,可以用来创建各种脏乱砖块材料。这个50分钟的教程适合所有技能水平的人。整个过程全程解说,一步步解释节点,从头到尾。你将获得以下内容-全高清分辨率、50分钟讲述视频-组织良好并带有注释的【.SBS】文件-包含暴露参数的【.SBSAR】文件-快速预览节点-依赖项现在就获取![点击这里](https://gumroad.com/l/uZqUeQ)
In this new Substance Designer tutorial, youll learn how to create a sloppy brick material from start to finish. Youll also learn some other techniques which help you understand how to achieve the realistic mortar and also some similar workflows.At the end of this tutorial you will have good understanding of the techniques behind creating this type of material and a graph that is commented and editable to create a wide variety of sloppy brick materials. This 50 Minutes tutorial is for all skill levels. The process is fully narrated, step-by-step  explained node-by-node, from start to finish.WHAT YOULL GET-Full HD Resolution 50 minutes narrated video.-Well organized and commented [.SBS] File.-[.SBSAR] File with exposed parameters.-Quick Preview Node.-Dependencies.GET YOURS NOW!https//gumroad.com/l/uZqUeQ
参与人数 1 元素币 +9 活跃度 +2
A站:https://www.artstation.com/abderrezakbouhedda
Abderrezak 实名
Material & Shader Artist (
