element3ds.com
SD-材质作品 Sand Ground - Substance Designer
33262
[翻译] : 大家好!最近怎么样?这是一个新的沙地。我在四个图(沙、岩石、草和海草)上展示了大量参数,这样你们可以做出很多组合!我会给你们完整的图(.sbs)文件,这样你们可以查看、编辑、预览新纹理等。我还会提供我用来渲染的六套纹理包。Gumroad链接:https://gum.co/EtvEb Cubebrush链接:http://cbr.sh/c0opuo
Hi guys! How is it going? This is a new Sand Ground. I exposed a lot of parameters on the 4 graphs, (sand, rocks, grass and seagrass) so you can make a lot of combinations! I will give you the full Graphs (.sbs) so you can see, edit, play, export new textures, etc...And I give you the 6 sets of textures that I used for these renderes too.Gumroad https//gum.co/EtvEbCubebrush http//cbr.sh/c0opuo
参与人数 1 元素币 +5 活跃度 +5
https://angelfernandes.artstation.com/
Angel_Fernandes 实名
Material Artist at Infinity Wa
