element3ds.com
3D角色_武器_装备 [欧美写实] ModMesh
3695
1
Start from a pre built mesh or design your own from over 28 million possible combinations. Check It Out! http//ModMesh.xyzModMeshs simple and beautiful design will get you heading towards a finished character in no time. Modular, easy to use, and uniquely appealing. Where most base meshes are too rigid in style and difficult to manipulate, ModMesh gives you the tools to quickly and easily design exactly what you need.Choose from 31 pre built heads, effortlessly create your own from millions of possible combinations, or let randomness take over and decide for you.-Features-31 Unique, High Quality, Pre Built Head Base MeshesBuild Your Own Assembly File with completely modular parts that are easy to combine into something uniqueMillions of possible combinations (28,629,151 to be precise... well technically more but whos counting?)Appealing forms that subdivide cleanly and combine effortlessly.Unique names for referencing each pre built head and partWill work with nearly any 3D software and designed to work even better with ZBrush-Files Included-31 Pre Built, Unique Head Base Meshes (ZTL  FBX)Assembly File with Split and Organized Parts to Create Your Own Unique Head (ZTL  FBX)Example File containing 10 Heads, Combined from Different Parts (ZTL  FBX)Tutorial Video Showing Best Practices and Tips for Working with ModMesh (MP4)Check It Out! http//ModMesh.xyz
参与人数 1 元素币 +9 活跃度 +1
Artstation:https://www.artstation.com/follygon
qq_醉红尘_Fsz  发表于 2025-2-27 12:37:04
Follygon 实名
3D角色艺术家
