[计算机] 什么是内网穿透?
查看:35253 |回复:2 | 2023-7-28 10:40:20
什么是内网穿透?
参与人数 3元素币 +19 活跃度 +9 展开 理由
blue0904 + 4 + 3 顶下
介炮家龙 + 7 + 4 啊,这...
Chen23 + 8 + 2 这是我能看的吗?
2023-7-28 10:40:20
2个回答,把该问题分享到群,邀请大神一起回答。
内网穿透是一种技术,它允许你在不公开真实IP地址的情况下,通过互联网访问内部网络中的设备或服务。内网穿透通过在公网上搭建一个服务器,将外部请求转发到内网中的指定设备或服务。这样,即使你的设备被动态IP地址或NAT(Network Address Translation)所限制,也可以通过内网穿透技术实现远程访问。
What is port forwarding?
Port forwarding is a technique that allows you to access devices or services on your internal network through the internet without revealing your true IP address. It involves setting up a server on the public network to forward external requests to specific devices or services on your internal network. This way, even if your device has a dynamic IP address or is behind a NAT (Network Address Translation), you can still achieve remote access using port forwarding.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-7-28 10:40:28   回复
不错不错,楼主您辛苦了。。。
2023-7-28 15:00:36   回复
