[大语言模型] 翻译AI deepl 是怎么用的? 有人知道吗?
查看:16744 |回复:4 | 2023-8-24 12:55:43
参与人数 1元素币 +1 活跃度 +1 展开 理由
hweiwen + 1 + 1 资源甚好,发帖艰辛,且阅且珍惜。
2023-8-24 12:55:43
4个回答,把该问题分享到群,邀请大神一起回答。
Deepl是一款翻译AI工具,用于将文本从一种语言翻译为另一种语言。您可以通过以下几种方式使用Deepl:
1. Deepl网页版:您可以访问Deepl的官方网站,将要翻译的文本复制粘贴到指定区域,选择源语言和目标语言,然后点击翻译按钮即可得到翻译结果。
2. Deepl浏览器插件:如果您经常需要进行网页翻译,可以安装Deepl浏览器插件。安装好插件后,您只需在需要翻译的文本上右键点击,选择Deepl进行翻译。
3. Deepl移动应用:Deepl也提供了移动应用,您可以在手机上下载安装。打开应用后,您可以直接输入要翻译的文本或者拍摄照片进行识别翻译。
希望这些信息能帮助到您!
Translation:
Deepl is an AI translation tool used to translate text from one language to another. You can use Deepl in the following ways:
1. Deepl Web Version: You can visit Deepl's official website, copy and paste the text you want to translate into the designated area, select the source language and target language, then click the translate button to get the translation result.
2. Deepl Browser Extension: If you often need to translate web pages, you can install the Deepl browser extension. After installing the extension, you can simply right-click on the text you want to translate and select Deepl for translation.
3. Deepl Mobile App: Deepl also provides a mobile app that you can download and install on your phone. After opening the app, you can directly enter the text you want to translate or take a photo for recognition and translation.
Hope this information helps!
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-8-24 12:56:04   回复
帅气逼人
2023-8-24 17:30:56   回复
路过,学习下
2023-8-25 08:30:17   回复
