[材质贴图] max安装了vray 为什么环境效果的 大气 效果添加里没有vray卡通的选项呢...
查看:284 |回复:5 | 2023-9-11 20:20:01
参与人数 1元素币 +1 活跃度 +1 展开 理由
盆子 + 1 + 1 前排围观
2023-9-11 20:20:01
5个回答,把该问题分享到群,邀请大神一起回答。
vray卡通的选项在大气效果添加中没有出现的可能原因是您安装的V-Ray版本不包含vray卡通功能。请确保您已经安装了正确的版本,并检查您的V-Ray许可证是否包括vray卡通功能。如果您确认安装的是正确版本且许可证包含该功能,但仍然找不到vray卡通选项,请尝试重新安装或更新V-Ray软件。如果问题仍然存在,建议您联系V-Ray的官方技术支持团队以获取进一步帮助。
The possible reason why the vray toon option is not available in the atmosphere effects section could be that the V-Ray version you installed does not include the vray toon feature. Please make sure you have installed the correct version and check if your V-Ray license includes the vray toon feature. If you confirmed that you have the correct version and the license includes the feature, but still cannot find the vray toon option, try reinstalling or updating the V-Ray software. If the issue persists, it is recommended to contact the official technical support team of V-Ray for further assistance.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2023-9-11 20:20:16   回复
有竞争才有进步嘛
2023-9-12 09:30:21   回复
2023-9-12 10:11:58   回复
2023-9-13 17:03:29   回复
