用掉元素币、积分和微金等资源不会直接导致等级下降。一旦你升级到元素皇,你的等级将保持不变,即使你花费了这些资源。你不会被降回到元素王等级。
Using up Element Coins, points, and micro gold resources will not directly cause your level to decrease. Once you have upgraded to Element Sovereign, your level will remain the same, even if you spend these resources. You will not be demoted back to Element King level.
——微元素 × GPT,助力游戏开发,CG创作的无限可能! |
