[积分] [外挂]持续增加, 开始 对 智慧兑换 和 活跃兑换进行人工审查,避免侥幸心理误入歧途...
查看:15183 |回复:11 | 2024-2-2 10:49:22
最近发现,夜间有大量外挂运行,严重影响了 元素装备系统的夜间正常运作
分析后发现很多账号,可能是被盗号,夜间疯狂刷点赞, 刷原创技能点来获取智慧!
现决定对智慧 和 活跃行为开启人工审核.
所有半夜不睡觉 ,坚持点一了晚上的全部扣除!
审核的标准为:
获取点赞的回答必须是有意义,真对主题问题的.
无意义的表情和 互赞, 几个符号,  恭维之类的回复 ,获取点赞数量较高均无法通过100% 兑换, 获取的比例按照有效回复和有意义的交互比例计算
抽查全部无意义, 则直接按照0%兑换.
账号疯狂给别人点赞, 可能是被盗号, 并不会被处罚.请尽快修改密码避免财产损失.
谁收益则检查谁的内容规范性.
疯狂用外挂点赞自己无意义回复,被处罚的案例,请大家引以为戒.
避免浪费电力.
2024-2-2 10:49:22
 赞 赞 5
11个回答,把该问题分享到群,邀请大神一起回答。
最近发现夜间有很多外挂程序在运行,严重影响了元素装备系统的正常运作。经过分析发现,很多账号可能被盗号,夜间疯狂刷点赞、刷原创技能点以获取智慧。为了避免这种问题的出现,我们决定对智慧兑换和活跃兑换进行人工审核。
审核的标准如下:
1. 获取点赞的回答必须是有意义的,针对主题问题进行回复。
2. 无意义的表情、互赞、只含有几个符号或恭维之类的回复,无论点赞数量有多高,都无法100%兑换。获取的比例将按照有效回复和有意义的交互比例进行计算。
3. 如果抽查全部回复都无意义,那么将直接按照0%兑换。
如果一个账号疯狂给别人点赞,可能意味着该账号被盗号,并不会受到处罚。请尽快修改密码以避免财产损失。谁从中受益,就检查谁的内容是否符合规范。
Recently, we have noticed a significant increase in fraudulent activities, so we have decided to conduct manual reviews on Wisdom and Active Exchange to prevent any misunderstandings.
We have recently discovered that there are a large number of cheating programs running at night, which seriously affect the normal operation of the Elemental Equipment System. After analysis, we found that many accounts may have been stolen and are using these cheating programs to generate likes and original skill points overnight in order to obtain Wisdom.
Therefore, we have decided to implement manual reviews for Wisdom and Active behaviors.
The review standards are as follows:
- The answers that receive likes must be meaningful and directly related to the topic.
- Replies that consist of meaningless emojis, mutual likes, a few symbols, or compliments will not be eligible for 100% exchange, regardless of the number of likes received. The exchange ratio will be calculated based on the proportion of valid replies and meaningful interactions.
- If all the replies are found to be meaningless during spot checks, the exchange rate will be set to 0%.
Accounts that excessively like others' content may have been hacked and will not be penalized. We recommend changing your password as soon as possible to prevent any financial losses. The compliance of content will be checked for those who benefit from the exchange.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2024-2-2 10:49:34   回复
 赞 赞 5
2024-2-2 11:19:39   回复
 赞 赞 5
牛,什么神仙都有
2024-2-2 11:20:00   回复
 赞 赞 7
2024-2-2 13:54:02   回复
 赞 赞 4
这都有外挂 国人也真是神奇
2024-2-4 08:34:31   回复
 赞 赞 4
2024-2-4 19:12:19   回复
2024-2-22 13:00:55   回复
2024-2-23 16:16:40   回复
2024-2-23 16:16:49   回复
真的猛一晚上不睡觉,只为智慧币
2024-5-26 17:11:26   回复
