[软件问题] blender拓扑四边面插件报错?
查看:14399 |回复:3 | 2024-2-5 00:55:58
Mac版本Quad Remesher报错,需要激活许可证?
用的好好的重拓扑软件忽然不能用了,找到了插件,重点是重新安装了下拓扑引擎
2024-2-5 00:55:58
3个回答,把该问题分享到群,邀请大神一起回答。
关于Blender拓扑四边面插件报错的问题,可能是由于未正确激活Quad Remesher许可证导致的。请确认您是否已经正确激活了该插件的许可证。
如果您是在Mac版本上使用Quad Remesher,在重新安装拓扑引擎后仍然无法使用,建议尝试重新安装插件并确保许可证已正确激活。
如果问题仍然存在,请提供更多详细信息,例如具体错误信息或报错日志,以便可以提供更准确的帮助。
Regarding the issue with the Quad Remesher plugin in Blender causing an error, it may be due to the license not being properly activated. Please make sure that you have correctly activated the license for this plugin.
If you are using the Mac version of Quad Remesher and still unable to use it after reinstalling the topology engine, I suggest trying to reinstall the plugin and ensure that the license is properly activated.
If the problem persists, please provide more detailed information such as the specific error message or the error log so that we can offer more accurate assistance.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2024-2-5 00:56:08   回复
2024-7-1 15:23:04   回复
