[软件问题] 框选不了模型小部分点线面
查看:349 |回复:3 | 2024-2-5 11:55:38
选择模型后框选只能大面积的框选点线面,框选不了小面积的点线面,而且大面积框选的时候还会漏选,这是什么原因?怎么解决
2024-2-5 11:55:38
3个回答,把该问题分享到群,邀请大神一起回答。
可能是因为模型的精度较高,导致框选时的选择器的敏感度不足以捕捉到小面积的点线面。这可能是软件本身的限制。解决办法可以尝试使用其他选择方式,例如按住Ctrl键逐个选择较小的点线面,或者缩小视图来更精确地进行选择。
It is possible that the high precision of the model makes it difficult for the selection tool to accurately capture small areas of points, lines, or faces when using the box selection. This may be a limitation of the software itself. To solve this issue, you can try using alternative selection methods, such as individually selecting smaller areas by holding down the Ctrl key, or zooming in on the view to make more precise selections.
   ——微元素 × GPT,助力游戏开发,CG创作的无限可能!
2024-2-5 11:55:42   回复
2024-2-5 18:04:05   回复
