element3ds.com
SD-材质作品 Gumroad - Palm Material _ Palm Model Including SpeedTree Project _amp; Marmoset Toolbag Scene
32824
1
[翻译] : 在Gumroad上提供:.这份材料提供了许多高级棕榈树皮材质的制作技巧和全过程,你可以深入研究并使用完整的、带有注释的SBS Substance Designer文件,创造出无限多的变体。此外,还包含一个游戏就绪的棕榈树模型,附带在Marmoset Toolbag文件中,可以实时预览棕榈树的外观。因此,这个产品将帮助你节省时间并提升质量。你将获得:
- 预制好的棕榈树皮纹理
- 包含所有纹理的棕榈树.obj模型
- 包含SpeedTree Modeler项目,你可以用来自定义创建自己的...
Available on Gumroad :
https://gumroad.com/l/XuFYVF
This Material gives you alot of tips and tricks showing the whole creation process of advanced palm tree bark material, you can dig into the full and commented source SBS substance designer file and create your own infinite variations. also the Palm Tree Model is a Game-Ready model well created and included in the marmoset toolbag file to see how the Palm looks like in realtime renderer . so this product will help you gain time _ quality toghether .
WHAT YOU_LL GET :
-Palm TreeBark Textures Ready to use
-Palm Tree Model .obj including all textures as well
-SpeedTree Modeler Project included so you can create your own
参与人数 3 元素币 +20 活跃度 +8
A站:https://www.artstation.com/abderrezakbouhedda
ZhBJ2009  发表于 2024-7-2 11:42:36
有资产下载吗
Abderrezak 实名
Material & Shader Artist (
