element3ds.com
SD-材质作品 Substance Designer - Chaos Blades
33230
[翻译] : 想在Designer中尝试一些新东西,所以我完全用Substance Designer制作了《战神》中的混沌之刃。工作流程是使用镜像平面和高度图。链环部分也是类似,我用了两个平面,并通过高度图创建了链条。它可以直接导入ZBrush中,然后遮罩出刀片,进行重拓扑,你就得到了低poly游戏就绪的资产。很多灵感来源于Daniel Thiger的作品——“ rapier sword”。
Wanted to experiment with something new in Designer, so I made the Chaos Blades from God Of War entirely in Substance Designer. The workflow is using mirrored planes with heightmap. Same is for the chain links where I used two planes and made the chain using heightmap as well. It could be taken into ZBrush, mask out the blade, retopo it and you_ll have the low poly game ready asset
A lot of inspiration came from Daniel Thiger work _Rapier Sword_
343_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-01.jpg
344_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-02.jpg
345_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-03.jpg
347_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-04.jpg
348_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-05.jpg
349_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-07.jpg
350_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-09.jpg
351_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-06.jpg
352_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-08-artstation.jpg
353_enrico-tammekand-god-of-war-chaos-blades-substance-designer-allegorithmic-procedural-material-texture-enrico-tammekand-enthelity-studios-preview-10.jpg
参与人数 3 元素币 +22 活跃度 +4
Artstation:https://www.artstation.com/enricot
Enrico 实名
高级材料美术师
