element3ds.com
SD-材质作品 Ultimate Smart Masks _ Free Tutorial and Samples Vol 05
33075
1
[翻译] : 包含在包中:高质量预览100个智能面具(SPSM)免费教程免费样本此包的好处:无需努力纹理(拖放)逼真外观高质量预览每层都有正确的名称和颜色不重定制100%使用Substance Painter制作所有材质已通过PBR验证器检查兼容 Substance 3D Painter,版本8.2.0及以上自定义抽屉预览所有图案均使用Substance Painter的默认纹理和映射通过形状操作创建类别:苔藓、灰尘、破损织物、牛仔布破损、弹孔痕迹、污垢材料、尘埃材料、泄漏、剥落油漆、皮革补丁、牛仔布补丁、亚麻补丁、织物结构、划痕、木纹将_spmsk_文件复制到您的Substance Painter抽屉文件夹*Substance 3D Painter,版本8.2.0或更高注意:在9.1版本中,应用智能面具后需要手动关联参考。
A pack of 100 High-Detail and completely customizable smart masks (spmsk) to increase realism and enhance your workflow.
Download:
https://www.artstation.com/a/35081317
Included in the pack:
High-quality preview
100 smart mask (SPSM)
Free Tutorial
Free Sample
Benefits of this pack:
No effort texturing (drag and drop)
Realistic look
Each layer has the correct name and color
Not heavy
Customizable
100% made with substance painter
All materials checked with PBR validator
compatible Substance 3D Painter, version 8.2.0 and higher
custom shelf previews
All patterns are created with shape manipulation using default textures and maps in substance painter
Category: moss, dust, fabric torn, denim torn, bullet impact, dirt material, dust material, leak, peeling paint, leather patch, denim patch, linen patch, Fabric structure, scratch, Wood pattern
Copy the file _spmsk _ into your Substance Painter shelf folder
*Substance 3D Painter, version 8.2.0 or higher
Note: In version 9.1 after applying the smart mask you need to link the reference manually.
参与人数 3 元素币 +16 活跃度 +8
A站:https://www.artstation.com/javad-rajabzade
hhhappy  发表于 2024-6-25 21:18:35
沙发
Javad_Rajabzade 实名
Texture Artist / Look Dev
