element3ds.com
地编-CG场景 Paleontology Skeleton Photogrammetry UE5
22401
1
[翻译] : 我很高兴向大家展示我的最新摄影测量项目!我决定跳出舒适区,不再专注于植物:)我花了一天时间在巴黎的古生物学与比较解剖学博物馆,尽可能多地拍摄照片,看看能创造出什么。我在博物馆里花了8个小时拍摄不同的骨架。这个项目很有趣,因为我对数据采集没有完全控制权。我不能控制光线,不能使用闪光灯消除阴影,也不能随意移动或靠近骨架,这些限制迫使我发挥创意,并在后期清洁阶段格外用心。所有照片都在Lightroom中处理,然后发送到RealityCapture,我在那里花了大量时间清理模型。接着在ZBrush中进行平滑和修改某些部分。最后,制作低多边形模型并创建UV贴图,将它们发送到Designer和Painter,以尽可能修正缺陷。我拍摄了大约15具骨架,但这里只展示那些最终效果好、经受住整个流程的。我使用的是索尼A7RIII和sigma 35-70mm镜头,光圈F8到F11。每具骨架大约包含300-500张45MPX的照片。所有的渲染都在UE5中完成,得益于Atlux这款出色的插件。希望最终结果能满足我的期待。感谢大家!
I am very happy to show you my latest photogrammetry project ! I wanted to step out of my comfort zone and my usual focus on vegetation :p
I decided to spend a day in Paris and take as many photos as possible at the Gallery of Paleontology and Comparative Anatomy to see what I could create. I spent 8 hours in the museum photographing the different skeletons. I found the project interesting because I didn_t have complete control over the data capture. I couldn_t control the lighting, I couldn_t use my flash to eliminate shadows, and I couldn_t move freely or get very close to the skeletons. All these constraints forced me to be creative and pay a lot of attention to the cleaning phase. All the photos were processed in Lightroom and then sent to RealityCapture, where I spent a lot of time cleaning the models. Then, a pass in ZBrush to smooth and modify certain parts. Finally, the creation of a low poly and UVs to send everything to Designer and Painter to correct as many defects as possible.
I photographed about 15 skeletons, but here I am showing the ones that turned out the best and withstood the whole process.
I used a Sony A7RIII and a Sigma 35-70mm lens, F8 to F11. Each skeleton contains about 300-500 photos, each  45 MPX. Everything is rendered inside UE5 with the help of the great plugin Atlux !
I hope the result meets my expectations.
Thank you, everyone!
参与人数 3 元素币 +11 活跃度 +6
https://www.artstation.com/ducrocq_hugo
fengyu123  发表于 2024-7-13 18:50:35
Hugo_Ducrocq 实名
Environment/Vegetation Artist
