element3ds.com
3D角色_武器_装备 Leupold DeltaPoint_ Pro
21185
1
[翻译] : Sorry!Error
The Leupold DeltaPoint_ Pro is a reflex sight that is designed for use on firearms such as handguns, rifles, and shotguns. It features a 2.5 MOA red dot reticle that is adjustable for brightness and windage/elevation. The sight is made with aircraft-grade aluminum and is waterproof, fogproof, and shockproof. It is also compatible with a variety of mounting systems, making it adaptable to a wide range of firearms. The Leupold DeltaPoint_ Pro is known for its durability, clarity and quick target acquisition.
Special thanks to the good community at The Weapons Room, got some valuable ideas and pointers from there! _
Modelled in Blender
Baked with Marmoset Toolbag 4
Textured with Substance Painter
Rendered using Cycles _ Eevee
The LOD0 uses a total of 4,031 vertices, uses one 2048x1024 Texture-Set for opaque geometry and one 512x512 Texture-Set for the glass. The entire model sits at an average Texel Density of 125px.
参与人数 3 元素币 +11 活跃度 +10
Artstation:https://www.artstation.com/roartal/albums/all
qq_醉红尘_Fsz  发表于 2024-12-22 13:13:29
Markus_K 实名
3D艺术家
