element3ds.com
3D角色_武器_装备 SPIDER-TANK 2024
12163
1
[翻译] : 专为3D打印设计的这款蜘蛛坦克零件,是在CAD软件中精确建模的,以确保最大程度的精度和准确性。它由10个单独的部分组成,通过装配指南PDF完美契合。您可以下载原始模型或打印就绪模型,后者是中空并带有支撑结构。Chitubox文件也提供,以便您自由定制偏好属性。尺寸:长:250毫米 宽:183毫米 高:66毫米 下载:mmf.io/o/405703
Designed this spider tank partcullarly for 3Dprinting purposes. It's precisely modeled in CAD softwares to ensure the maximum precision and accuracy. It's made up of 10 separate pieces which fit together perfectly thanks to the assembling guide PDF. You may download the original model or the print ready model, which is hollowed and supported. Chitubox files are also available for you to customize your preferences attributes freely.
Dimensions: length:250mm width:183mm height:66mm
Download:
mmf.io/o/405703
https://www.instagram.com/mhattaran/
回复
qq_醉红尘_Fsz  发表于 2024-11-27 12:44:13
mhattaran 实名
Sci-Fi Concept Artist- Availab
