element3ds.com
SD-材质作品 Marble _amp; Gold Trim Sheet - With Examples - 100_ Substance Designer
712
Trim Sheet material I made for a client & made some changes & improvements for a bit of a variated version which you can see here, Most of the good trim sheet work I did before is under NDA, first time I post a trim sheet work here.  This one I used a plane & disk meshes to do very simple & quick UV-ing, we can create a whole environment with just two trim sheets or even one sometimes. Let me know what you think in the comments.
A站:https://www.artstation.com/abderrezakbouhedda
回复
Abderrezak 实名
Material & Shader Artist (
