今天,小编为大家分享一下,如何做到一个虚拟摇杆实现物体的移动和特定的操作。下面是简单通过虚拟摇杆可以实现摩托车的行驶。【PS:因为项目代码比较多,也许文章讲得不够全面清楚,希望大家能多多包涵。
如果大家想要源码或者资源的话,可以直接加QQ群:575561285】
好吧!废话不多讲,直接进入主题吧!
1.新建unity3d 项目,然后自己可以合理搭一个场景,导入需要的资源,例如,我这边会导入一些摩托车的模型。
2.首先考虑的是摩托车自身属性设置,然后可以给他们挂上脚本,属性:Pro_bike 5.js,控制声音:Bike_sound.js ,刹车控制:Skid Marks.js;
然后具体的代码如下:
Pro_bike 5.js
- #pragma strict
- /// Writen by Boris Chuprin smokerr@mail.ru
- ///////////////////////////////////////////////////////// wheels ///////////////////////////////////////////////////////////
- // defeine wheel colliders
- var coll_frontWheel : WheelCollider;
- var coll_rearWheel : WheelCollider;
- // visual for wheels
- var meshFrontWheel : GameObject;
- var meshRearWheel : GameObject;
- // check isn't front wheel in air for front braking possibility
- private var isFrontWheelInAir : boolean = true;
- //////////////////////////////////////// Stifness, CoM(center of mass), crahsed /////////////////////////////////////////////////////////////
- //for stiffness counting when rear brake is on. Need that to lose real wheel's stiffness during time
- private var stiffPowerGain : float = 0.0;
- //for CoM moving along and across bike. Pilot's CoM.
- private var tmpMassShift : float = 0.0;
- // crashed status. To know when we need to desable controls because bike is too leaned.
- public var crashed : boolean = false;
- // there is angles when bike takes status crashed(too much lean, or too much stoppie/wheelie)
- var crashAngle01: float;//crashed status is on if bike have more Z(side fall) angle than this // 70 sport, 55 chopper
- var crashAngle02: float;//crashed status is on if bike have less Z(side fall) angle than this // 290 sport, 305 chopper
- var crashAngle03: float;//crashed status is on if bike have more X(front fall) angle than this // 70 sport, 70 chopper
- var crashAngle04: float;//crashed status is on if bike have more X(back fall) angle than this // 280 sport, 70 chopper
- // define CoM of bike
- var CoM : Transform; //CoM object
- var normalCoM : float; //normalCoM is for situation when script need to return CoM in starting position // -0.77 sport, -0.38 chopper
- var CoMWhenCrahsed : float; //we beed lift CoM for funny bike turning around when crahsed // -0.2 sport, 0.2 chopper
- //////////////////// "beauties" of visuals - some meshes for display visual parts of bike ////////////////////////////////////////////
- var rearPendulumn : Transform; //rear pendulumn
- var steeringWheel : Transform; //wheel bar
- var suspensionFront_down : Transform; //lower part of front forge
- private var normalFrontSuspSpring : int; // we need to declare it to know what is normal front spring state is
- private var normalRearSuspSpring : int; // we need to declare it to know what is normal rear spring state is
- private var forgeBlocked : boolean = true; // variable to lock front forge for front braking
- //why we need forgeBlocked ?
- //There is little bug in PhysX 3.3 wheelCollider - it works well only with car mass of 1600kg and 4 wheels.
- //If your vehicle is not 4 wheels or mass is not 1600 but 400 - you are in troube.
- //Problem is absolutely epic force created by suspension spring when it's full compressed, stretched or wheel comes underground between frames(most catastrophic situation)
- //In all 3 cases your spring will generate crazy force and push rigidbody to the sky.
- //so, my solution is find this moment and make spring weaker for a while then return to it's normal condition.
- private var baseDistance : float; // need to know distance between wheels - base. It's for wheelie compensate(dont want wheelie for long bikes)
- // we need to clamp wheelbar angle according the speed. it means - the faster bike rides the less angle you can rotate wheel bar
- var wheelbarRestrictCurve : AnimationCurve = new AnimationCurve(new Keyframe(0f, 20f), new Keyframe(100f, 1f));//first number in Keyframe is speed, second is max wheelbar degree
- // temporary variable to restrict wheel angle according speed
- private var tempMaxWheelAngle : float;
- //variable for cut off wheel bar rotation angle at high speed
- private var wheelPossibleAngle : float = 0.0;
- //for wheels vusials match up the wheelColliders
- private var wheelCCenter : Vector3;
- private var hit : RaycastHit;
- /////////////////////////////////////////// technical variables ///////////////////////////////////////////////////////
- static var bikeSpeed : float; //to know bike speed km/h
- static var isReverseOn : boolean = false; //to turn On and Off reverse speed
- // Engine
- var frontBrakePower : float; //brake power absract - 100 is good brakes // 100 sport, 70 chopper
- var EngineTorque : float; //engine power(abstract - not in HP or so) // 85 sport, 100 chopper
- // airRes is for wind resistance to large bikes more than small ones
- var airRes : float; //Air resistant // 1 is neutral
- /// GearBox
- var MaxEngineRPM : float; //engine maximum rotation per minute(RPM) when gearbox should switch to higher gear // 12000 sport, 7000 chopper
- var EngineRedline : float; // 12200 sport, 7200 chopper
- var MinEngineRPM : float; //lowest RPM when gear need to be switched down // 6000 sport, 2500 chopper
- static var EngineRPM : float; // engine current rotation per minute(RPM)
- // gear ratios(abstract)
- var GearRatio: float[];//array of gears // 6 sport, 5 chopper
- var CurrentGear : int = 0; // current gear
- private var ctrlHub : GameObject;// gameobject with script control variables
- private var outsideControls : controlHub;// making a link to corresponding bike's script
- /////////////////////////////////////////////////// ESP system ////////////////////////////////////////////////////////
- private var ESP : boolean = false;//ESP turned off by default
- //////////////////////////////////////////////// ON SCREEN INFO ///////////////////////////////////////////////////////
- function OnGUI ()
- var biggerText = new GUIStyle("label");
- biggerText.fontSize = 40;
- var middleText = new GUIStyle("label");
- middleText.fontSize = 22;
- var smallerText = new GUIStyle("label");
- smallerText.fontSize = 14;
- //to show in on display interface: speed, gear, ESP status
- GUI.color = Color.black;
- GUI.Label(Rect(Screen.width*0.9,Screen.height*0.67, 120, 80), String.Format(""+ "{0:0.}", bikeSpeed), biggerText);
- GUI.Label (Rect (Screen.width*0.725,Screen.height*0.64, 60, 80), "" + (CurrentGear+1),biggerText);
- if (!ESP){
- GUI.color = Color.grey;
- GUI.Label (Rect (Screen.width*0.885, Screen.height*0.55,60,40), "ESP", middleText);
- } else {
- GUI.color = Color.green;
- GUI.Label (Rect (Screen.width*0.885, Screen.height*0.86,60,40), "ESP", middleText);
- if (!isReverseOn){
- GUI.Label (Rect (Screen.width*0.885, Screen.height*0.96,60,40), "REAR", smallerText);
- } else {
- GUI.color = Color.red;
- // user info help lines
- GUI.color = Color.white;
- GUI.Box (Rect (10,10,180,20), "A,W,S,D - main control", smallerText);
- GUI.Box (Rect (10,25,220,20), "2 - more power to accelerate", smallerText);
- GUI.Box (Rect (10,40,120,20), "X - rear brake", smallerText);
- GUI.Box (Rect (10,55,320,20), "Q,E,F,V - shift center of mass of biker", smallerText);
- GUI.Box (Rect (10,70,320,20), "R - restart / RightShift+R - full restart", smallerText);
- GUI.Box (Rect (10,85,180,20), "RMB - rotate camera around", smallerText);
- GUI.Box (Rect (10,100,120,20), "Z - turn on/off ESP", smallerText);
- GUI.Box (Rect (10,115,320,20), "C - toggle reverse", smallerText);
- function Start () {
- ctrlHub = GameObject.Find("gameScenario");//link to GameObject with script "controlHub"
- outsideControls = ctrlHub.GetComponent(controlHub);//to connect c# mobile control script to this one
- var setInitialTensor : Vector3 = GetComponent.<Rigidbody>().inertiaTensor;//this string is necessary for Unity 5.3 with new PhysX feature when Tensor decoupled from center of mass
- GetComponent.<Rigidbody>().centerOfMass = Vector3(CoM.localPosition.x, CoM.localPosition.y, CoM.localPosition.z);// now Center of Mass(CoM) is alligned to GameObject "CoM"
- GetComponent.<Rigidbody>().inertiaTensor = setInitialTensor;////this string is necessary for Unity 5.3 with new PhysX feature when Tensor decoupled from center of mass
- // wheel colors for understanding of accelerate, idle, brake(white is idle status)
- meshFrontWheel.GetComponent.<Renderer>().material.color = Color.black;
- meshRearWheel.GetComponent.<Renderer>().material.color = Color.black;
- //for better physics of fast moving bodies
- GetComponent.<Rigidbody>().interpolation = RigidbodyInterpolation.Interpolate;
- // too keep EngineTorque variable like "real" horse powers
- EngineTorque = EngineTorque * 20;
- //*30 is for good braking to keep frontBrakePower = 100 for good brakes. So, 100 is like sportsbike's Brembo
- frontBrakePower = frontBrakePower * 30;//30 is abstract but necessary for Unity5
- //tehcnical variables
- normalRearSuspSpring = coll_rearWheel.suspensionSpring.spring;
- normalFrontSuspSpring = coll_frontWheel.suspensionSpring.spring;
- baseDistance = coll_frontWheel.transform.localPosition.z - coll_rearWheel.transform.localPosition.z;// now we know distance between two wheels
- function FixedUpdate (){
- // if RPM is more than engine can hold we should shift gear up
- EngineRPM = coll_rearWheel.rpm * GearRatio[CurrentGear];
- if (EngineRPM > EngineRedline){
- EngineRPM = MaxEngineRPM;
- ShiftGears();
- // turn ESP on (no stoppie, no wheelie, no falls when brake is on when leaning)
- ESP = outsideControls.ESPMode;
- ApplyLocalPositionToVisuals(coll_frontWheel);
- ApplyLocalPositionToVisuals(coll_rearWheel);
- //////////////////////////////////// part where rear pendulum, wheelbar and wheels meshes matched to wheelsColliers and so on
- //beauty - rear pendulumn is looking at rear wheel
- rearPendulumn.transform.localRotation.eulerAngles.x = 0-8+(meshRearWheel.transform.localPosition.y*100);
- //beauty - wheel bar rotating by front wheel
- suspensionFront_down.transform.localPosition.y =(meshFrontWheel.transform.localPosition.y - 0.15);
- meshFrontWheel.transform.localPosition.z = meshFrontWheel.transform.localPosition.z - (suspensionFront_down.transform.localPosition.y + 0.4)/5;
- // debug - all wheels are white in idle(no accelerate, no brake)
- // drag and angular drag for emulate air resistance
- if (!crashed){
- GetComponent.<Rigidbody>().drag = GetComponent.<Rigidbody>().velocity.magnitude / 210 * airRes; // when 250 bike can easy beat 200km/h // ~55 m/s
- GetComponent.<Rigidbody>().angularDrag = 7 + GetComponent.<Rigidbody>().velocity.magnitude/20;
- //determinate the bike speed in km/h
- bikeSpeed = Mathf.Round((GetComponent.<Rigidbody>().velocity.magnitude * 3.6)*10) * 0.1; //from m/s to km/h
- //////////////////////////////////// acceleration & brake /////////////////////////////////////////////////////////////
- //////////////////////////////////// ACCELERATE /////////////////////////////////////////////////////////////
- if (!crashed && outsideControls.Vertical >0 && !isReverseOn){//case with acceleration from 0.0 to 0.9 throttle
- coll_frontWheel.brakeTorque = 0;//we need that to fix strange unity bug when bike stucks if you press "accelerate" just after "brake".
- coll_rearWheel.motorTorque = EngineTorque * outsideControls.Vertical;
- // debug - rear wheel is green when accelerate
- meshRearWheel.GetComponent.<Renderer>().material.color = Color.green;
- // when normal accelerating CoM z is averaged
- CoM.localPosition.z = 0.0 + tmpMassShift;
- CoM.localPosition.y = normalCoM;
- //case for reverse
- if (!crashed && outsideControls.Vertical >0 && isReverseOn){
- coll_rearWheel.motorTorque = EngineTorque * -outsideControls.Vertical/10+(bikeSpeed*50);//need to make reverse really slow
- //////////////////////////////////// ACCELERATE full throttle ///////////////////////////////////////////////////////
- if (!crashed && outsideControls.Vertical >0.9 && !isReverseOn){// acceleration >0.9 throttle for wheelie
- coll_rearWheel.motorTorque = EngineTorque * 1.2;//1.2 mean it's full throttle
- GetComponent.<Rigidbody>().angularDrag = 20;//for wheelie stability
- if (!ESP){// when ESP we turn off wheelie
- CoM.localPosition.z = -(2-baseDistance/1.4) + tmpMassShift;// we got 1 meter in case of sportbike: 2-1.4/1.4 = 1; When we got chopper we'll get ~0.8 as result
- //still working om best wheelie code
- var stoppieEmpower : float = (bikeSpeed/3)/100;
- // need to supress wheelie when leaning because it's always fall and it't not fun at all
- if (this.transform.localEulerAngles.z < 70){
- var angleLeanCompensate = this.transform.localEulerAngles.z/30;
- if (angleLeanCompensate > 0.5){
- angleLeanCompensate = 0.5;
- if (this.transform.localEulerAngles.z > 290){
- angleLeanCompensate = (360-this.transform.localEulerAngles.z)/30;
- if (stoppieEmpower + angleLeanCompensate > 0.5){
- stoppieEmpower = 0.5;
- CoM.localPosition.y = -(1 - baseDistance/2.8) - stoppieEmpower ;
- CoM.localPosition.y = CoM.localPosition.y += 0.002;
- //this is attenuation for rear suspension targetPosition
- //I've made it to prevent very strange launch to sky when wheelie in new Phys3
- if (this.transform.localEulerAngles.x > 200.0){
- coll_rearWheel.suspensionSpring.spring = normalRearSuspSpring + (360-this.transform.localEulerAngles.x)*500;
- if (coll_rearWheel.suspensionSpring.spring >= normalRearSuspSpring + 20000) coll_rearWheel.suspensionSpring.spring = normalRearSuspSpring + 20000;
- } else RearSuspensionRestoration();
- //////////////////////////////////// BRAKING /////////////////////////////////////////////////////////////
- //////////////////////////////////// front brake /////////////////////////////////////////////////////////
- if (!crashed && outsideControls.Vertical <0 && !isFrontWheelInAir){
- coll_frontWheel.brakeTorque = frontBrakePower * -outsideControls.Vertical;
- coll_rearWheel.motorTorque = 0; // you can't do accelerate and braking same time.
- //more user firendly gomeotric progession braking. But less stoppie and fun :( Boring...
- //coll_frontWheel.brakeTorque = frontBrakePower * -outsideControls.Vertical-(1 - -outsideControls.Vertical)*-outsideControls.Vertical;
- if (!ESP){ // no stoppie when ESP is on
- if (bikeSpeed >1){// no CoM pull up when speed is zero
- //when rear brake is used it helps a little to prevent stoppie. Because in real life bike "stretch" a little when you using rear brake just moment before front.
- if(outsideControls.rearBrakeOn){
- var rearBrakeAddon = 0.0025;
- CoM.localPosition.y = CoM.localPosition.y += (frontBrakePower/200000)+tmpMassShift/50-rearBrakeAddon;
- CoM.localPosition.z = CoM.localPosition.z += 0.05;
- else if (bikeSpeed <=1 && !crashed && this.transform.localEulerAngles.z < 45 || bikeSpeed <=1 && !crashed && this.transform.localEulerAngles.z >315){
- if (this.transform.localEulerAngles.x < 5 || this.transform.localEulerAngles.x > 355){
- if (CoM.localPosition.y >= -0.1) CoM.localPosition.y = -0.1;
- if (CoM.localPosition.z >= 0.2+(GetComponent.<Rigidbody>().mass/1100)) CoM.localPosition.z = 0.2+(GetComponent.<Rigidbody>().mass/1100);
- //this is attenuation for front suspension when forge spring is compressed
- //problem is launch bike to sky when spring must expand from compressed state. In real life front forge can't create such force.
- var maxFrontSuspConstrain : float;//temporary variable to make constrain for attenuation ususpension(need to make it always ~15% of initial force)
- maxFrontSuspConstrain = CoM.localPosition.z;
- if (maxFrontSuspConstrain >= 0.5) maxFrontSuspConstrain = 0.5;
- var springWeakness : int = normalFrontSuspSpring-(normalFrontSuspSpring*1.5) * maxFrontSuspConstrain;
- // debug - wheel is red when braking
- meshFrontWheel.GetComponent.<Renderer>().material.color = Color.red;
- //we need to mark suspension as very compressed to make it weaker
- forgeBlocked = true;
- } else FrontSuspensionRestoration(springWeakness);//here is function for weak front spring and return it's force slowly
- //////////////////////////////////// rear brake /////////////////////////////////////////////////////////
- // rear brake - it's all about lose side stiffness more and more till rear brake is pressed
- if (!crashed && outsideControls.rearBrakeOn){
- coll_rearWheel.brakeTorque = frontBrakePower / 2;// rear brake is not so good as front brake
- if (this.transform.localEulerAngles.x > 180 && this.transform.localEulerAngles.x < 350){
- coll_frontWheel.sidewaysFriction.stiffness = 1.0 - ((stiffPowerGain/2)-tmpMassShift*3);
- stiffPowerGain = stiffPowerGain += 0.025 - (bikeSpeed/10000);
- if (stiffPowerGain > 0.9 - bikeSpeed/300){ //orig 0.90
- stiffPowerGain = 0.9 - bikeSpeed/300;
- coll_rearWheel.sidewaysFriction.stiffness = 1.0 - stiffPowerGain;
- meshRearWheel.GetComponent.<Renderer>().material.color = Color.red;
- } else{
- coll_rearWheel.brakeTorque = 0;
- stiffPowerGain = stiffPowerGain -= 0.05;
- if (stiffPowerGain < 0){
- stiffPowerGain = 0;
- coll_rearWheel.sidewaysFriction.stiffness = 1.0 - stiffPowerGain;// side stiffness is back to 2
- coll_frontWheel.sidewaysFriction.stiffness = 1.0 - stiffPowerGain;// side stiffness is back to 1
- //////////////////////////////////// reverse /////////////////////////////////////////////////////////
- if (!crashed && outsideControls.reverse && bikeSpeed <=0){
- outsideControls.reverse = false;
- if(isReverseOn == false){
- isReverseOn = true;
- } else isReverseOn = false;
- //////////////////////////////////// turnning /////////////////////////////////////////////////////////////
- // there is MOST trick in the code
- // the Unity physics isn't like real life. Wheel collider isn't round as real bike tyre.
- // so, face it - you can't reach accurate and physics correct countersteering effect on wheelCollider
- // For that and many other reasons we restrict front wheel turn angle when when speed is growing
- //(honestly, there was a time when MotoGP bikes has restricted wheel bar rotation angle by 1.5 degree ! as we got here :)
- tempMaxWheelAngle = wheelbarRestrictCurve.Evaluate(bikeSpeed);//associate speed with curve which you've tuned in Editor
- if (!crashed && outsideControls.Horizontal !=0){
- //if (!crashed && Input.GetAxis("Horizontal") !=0){//DEL OLD
- // while speed is high, wheelbar is restricted
- coll_frontWheel.steerAngle = tempMaxWheelAngle * outsideControls.Horizontal;
- //coll_frontWheel.steerAngle = tempMaxWheelAngle * Input.GetAxis("Horizontal");//DEL OLD
- steeringWheel.rotation = coll_frontWheel.transform.rotation * Quaternion.Euler (0, coll_frontWheel.steerAngle, coll_frontWheel.transform.rotation.z);
- } else coll_frontWheel.steerAngle = 0;
- /////////////////////////////////////////////////// PILOT'S MASS //////////////////////////////////////////////////////////
- // it's part about moving of pilot's center of mass. It can be used for wheelie or stoppie control and for motocross section in future
- //not polished yet. For mobile version it should back pilot's mass smooth not in one tick
- if (outsideControls.VerticalMassShift >0){
- tmpMassShift = outsideControls.VerticalMassShift/12.5;//12.5 to get 0.08m at final
- CoM.localPosition.z = tmpMassShift;
- if (outsideControls.VerticalMassShift <0){
- if (outsideControls.HorizontalMassShift <0){
- CoM.localPosition.x = outsideControls.HorizontalMassShift/40;//40 to get 0.025m at final
- if (outsideControls.HorizontalMassShift >0){
- //auto back CoM when any key not pressed
- if (!crashed && outsideControls.Vertical == 0 && !outsideControls.rearBrakeOn || (outsideControls.Vertical < 0 && isFrontWheelInAir)){
- coll_frontWheel.motorTorque = 0;
- //autoback pilot's CoM along
- if (outsideControls.VerticalMassShift == 0){
- CoM.localPosition.z = 0.0;
- tmpMassShift = 0.0;
- //autoback pilot's CoM across
- if (outsideControls.HorizontalMassShift == 0){
- CoM.localPosition.x = 0.0;
- /////////////////////////////////////////////////////// RESTART KEY ///////////////////////////////////////////////////////////
- // Restart key - recreate bike few meters above current place
- if (outsideControls.restartBike){
- if (outsideControls.fullRestartBike){
- transform.position = Vector3(0,1,-11);
- transform.rotation=Quaternion.Euler( 0.0, 0.0, 0.0 );
- crashed = false;
- transform.position+=Vector3(0,0.1,0);
- transform.rotation=Quaternion.Euler( 0.0, transform.localEulerAngles.y, 0.0 );
- GetComponent.<Rigidbody>().velocity=Vector3.zero;
- GetComponent.<Rigidbody>().angularVelocity=Vector3.zero;
- //for fix bug when front wheel IN ground after restart(sorry, I really don't understand why it happens);
- ///////////////////////////////////////// CRASH happens /////////////////////////////////////////////////////////
- // conditions when crash is happen
- if ((this.transform.localEulerAngles.z >=crashAngle01 && this.transform.localEulerAngles.z <=crashAngle02) || (this.transform.localEulerAngles.x >=crashAngle03 && this.transform.localEulerAngles.x <=crashAngle04)){
- GetComponent.<Rigidbody>().drag = 0.1; // when 250 bike can easy beat 200km/h // ~55 m/s
- GetComponent.<Rigidbody>().angularDrag = 0.01;
- crashed = true;
- CoM.localPosition.y = CoMWhenCrahsed;//move CoM a little bit up for funny bike rotations when fall
- if (crashed) coll_rearWheel.motorTorque = 0;//to prevent some bug when bike crashed but still accelerating
- //function Update () {
- //not use that because everything here is about physics
- ///////////////////////////////////////////// FUNCTIONS /////////////////////////////////////////////////////////
- function ShiftGears() {
- if ( EngineRPM >= MaxEngineRPM ) {
- var AppropriateGear : int = CurrentGear;
- for ( var i = 0; i < GearRatio.length; i ++ ) {
- if (coll_rearWheel.rpm * GearRatio[i] < MaxEngineRPM ) {
- AppropriateGear = i;
- break;
- CurrentGear = AppropriateGear;
- if ( EngineRPM <= MinEngineRPM ) {
- AppropriateGear = CurrentGear;
- for ( var j = GearRatio.length-1; j >= 0; j -- ) {
- if (coll_rearWheel.rpm * GearRatio[j] > MinEngineRPM ) {
- AppropriateGear = j;
- break;
- function ApplyLocalPositionToVisuals (collider : WheelCollider) {
- if (collider.transform.childCount == 0) {
- return;
- var visualWheel : Transform = collider.transform.GetChild (0);
- wheelCCenter = collider.transform.TransformPoint (collider.center);
- if (Physics.Raycast (wheelCCenter, -collider.transform.up, hit, collider.suspensionDistance + collider.radius)) {
- visualWheel.transform.position = hit.point + (collider.transform.up * collider.radius);
- if (collider.name == "coll_front_wheel") isFrontWheelInAir = false;
- } else {
- visualWheel.transform.position = wheelCCenter - (collider.transform.up * collider.suspensionDistance);
- if (collider.name == "coll_front_wheel") isFrontWheelInAir = true;
- var position : Vector3;
- var rotation : Quaternion;
- collider.GetWorldPose (position, rotation);
- visualWheel.localEulerAngles = Vector3(visualWheel.localEulerAngles.x, collider.steerAngle - visualWheel.localEulerAngles.z, visualWheel.localEulerAngles.z);
- visualWheel.Rotate (collider.rpm / 60 * 360 * Time.deltaTime, 0, 0);
- //need to restore spring power for rear suspension after make it harder for wheelie
- function RearSuspensionRestoration (){
- if (coll_rearWheel.suspensionSpring.spring > normalRearSuspSpring){
- coll_rearWheel.suspensionSpring.spring = coll_rearWheel.suspensionSpring.spring -= 500;
- //need to restore spring power for front suspension after make it weaker for stoppie
- function FrontSuspensionRestoration (sprWeakness : int){
- if (forgeBlocked) {//supress front spring power to avoid too much force back
- coll_frontWheel.suspensionSpring.spring = sprWeakness;
- forgeBlocked = false;
- if (coll_frontWheel.suspensionSpring.spring < normalFrontSuspSpring){//slowly returning force to front spring
- coll_frontWheel.suspensionSpring.spring = coll_frontWheel.suspensionSpring.spring += 500;
点击此处复制文本
Bike_sound.js
- #pragma strict
- var linkToBike : pro_bike5;// making a link to corresponding bike's script
- //why it's here ? because you might use this script with many bikes in one scene
- var lastGear : int;//we need to know what gear is now
- private var highRPMAudio : AudioSource;// makeing second audioSource for mixing idle and high RPMs
- private var skidSound : AudioSource;// makeing another audioSource for skidding sound
- // creating sounds(Link it to real sound files at editor)
- var engineStartSound : AudioClip;
- var gearingSound : AudioClip;
- var IdleRPM : AudioClip;
- var highRPM : AudioClip;
- var skid : AudioClip;
- //we need to know is any wheel skidding
- var isSkidingFront : boolean = false;
- var isSkidingRear : boolean = false;
- private var outsideControls : controlHub;// making a link to corresponding bike's scriptt
- //assign sound to audioSource
- highRPMAudio = gameObject.AddComponent(AudioSource);
- highRPMAudio.loop = true;
- highRPMAudio.playOnAwake = false;
- highRPMAudio.clip = highRPM;
- highRPMAudio.pitch = 0;
- highRPMAudio.volume = 0.0;
- //same assign for skid sound
- skidSound = gameObject.AddComponent(AudioSource);
- skidSound.loop = false;
- skidSound.playOnAwake = false;
- skidSound.clip = skid;
- skidSound.pitch = 1.0;
- skidSound.volume = 1.0;
- //real-time linking to current bike
- linkToBike = this.GetComponent(pro_bike5);
- GetComponent.<AudioSource>().PlayOneShot(engineStartSound);
- playEngineWorkSound();
- lastGear = linkToBike.CurrentGear;
- function Update(){
- //Idle plays high at slow speed and highRPM sound play silent at same time. And vice versa.
- GetComponent.<AudioSource>().pitch = Mathf.Abs(linkToBike.EngineRPM / linkToBike.MaxEngineRPM) + 1.0;
- GetComponent.<AudioSource>().volume = 1.0 - (Mathf.Abs(linkToBike.EngineRPM / linkToBike.MaxEngineRPM));
- highRPMAudio.pitch = Mathf.Abs(linkToBike.EngineRPM / linkToBike.MaxEngineRPM);
- highRPMAudio.volume = Mathf.Abs(linkToBike.EngineRPM / linkToBike.MaxEngineRPM);
- // all engine sounds stop when restart
- GetComponent.<AudioSource>().Stop();
- GetComponent.<AudioSource>().pitch = 1.0;
- //gear change sound
- if (linkToBike.CurrentGear != lastGear){
- GetComponent.<AudioSource>().PlayOneShot(gearingSound);//звук переключения передач
- //skids sound
- if (linkToBike.coll_rearWheel.sidewaysFriction.stiffness < 0.5 && !isSkidingRear && linkToBike.bikeSpeed >1){//почему 0.5 ? как бы лучше это обыграть ?
- skidSound.Play();
- isSkidingRear = true;
- } else if (linkToBike.coll_rearWheel.sidewaysFriction.stiffness >= 0.5 && isSkidingRear || linkToBike.bikeSpeed <=1){
- skidSound.Stop();
- isSkidingRear = false;
- if (linkToBike.coll_frontWheel.brakeTorque >= (linkToBike.frontBrakePower-10) && !isSkidingFront && linkToBike.bikeSpeed >1){
- skidSound.Play();
- isSkidingFront = true;
- } else if (linkToBike.coll_frontWheel.brakeTorque < linkToBike.frontBrakePower && isSkidingFront || linkToBike.bikeSpeed <=1){
- skidSound.Stop();
- isSkidingFront = false;
- function playEngineWorkSound(){
- yield WaitForSeconds(1);//need a pause to hear ingnition sound first
- GetComponent.<AudioSource>().clip = IdleRPM;
- GetComponent.<AudioSource>().Play();
- highRPMAudio.Play();
点击此处复制文本
Skid Marks.js
- #pragma strict
- var skidMarkDecal : Transform;
- private var hit : WheelHit;
- private var skidMarkPos : Vector3;
- private var rotationToLastSkidmark : Quaternion;
- private var lastSkidMarkPos : Vector3;
- private var relativePos : Vector3;
- function FixedUpdate(){
- //skidmarks for rear wheel(braking drifting)
- if (linkToBike.coll_rearWheel.sidewaysFriction.stiffness < 0.5 && linkToBike.bikeSpeed >1){
- if (linkToBike.coll_rearWheel.GetGroundHit(hit)){
- skidMarkPos = hit.point;
- skidMarkPos.y += 0.02;
- skidMarkDecal.transform.localScale.x = 1.0;
- if (lastSkidMarkPos != Vector3.zero){
- relativePos = lastSkidMarkPos - skidMarkPos;
- rotationToLastSkidmark = Quaternion.LookRotation(relativePos);
- Instantiate(skidMarkDecal, skidMarkPos, rotationToLastSkidmark);
- lastSkidMarkPos = skidMarkPos;
- //skidmarks for front wheel(braking)
- if (linkToBike.coll_frontWheel.brakeTorque >= (linkToBike.frontBrakePower-10) && linkToBike.bikeSpeed >1){
- if (linkToBike.coll_frontWheel.GetGroundHit(hit)){
- skidMarkDecal.transform.localScale.x = 0.6;
- function Update () {
点击此处复制文本
【脚本参数设置如图】
3.接下来,我们需要在场景中,新建一个gameScenario游戏对象GameObject,作为整个游戏控制中心,并且在gameScenario对象中附加 速度控制:Speedometer.js
控制整个游戏对象:controlHub.cs
Speedometer.js
- //speedometer
- var GUIDashboard : Texture2D;
- var dashboardArrow : Texture2D;
- private var topSpeed: float;//220 for sport/ 180 for chopper
- private var stopAngle: float;//-200 for sport/ ... for chopper
- private var topSpeedAngle: float;
- var speed: float;
- //tachometer
- var chronoTex: Texture2D;
- private var topRPM: float;// 14000 for sport/ ... for chopper
- private var stopRPMAngle: float;//-200 for sport/... ... for chopper
- private var topRPMAngle: float;
- var RPM: float;
- //link to bike script
- linkToBike = GameObject.Find("rigid_bike").GetComponent("pro_bike5");
- findCurrentBike();
- function OnGUI() {
- // speedometer
- GUI.DrawTexture(Rect(Screen.width*0.85, Screen.height*0.55, GUIDashboard.width/2, GUIDashboard.height/2), GUIDashboard);
- var centre = Vector2(Screen.width*0.85 + GUIDashboard.width / 4, Screen.height*0.55 + GUIDashboard.height / 4);
- var savedMatrix = GUI.matrix;
- var speedFraction = speed / topSpeed;
- var needleAngle = Mathf.Lerp(stopAngle, topSpeedAngle, speedFraction);
- GUIUtility.RotateAroundPivot(needleAngle, centre);
- GUI.DrawTexture(Rect(centre.x, centre.y - dashboardArrow.height/4, dashboardArrow.width/2, dashboardArrow.height/2), dashboardArrow);
- GUI.matrix = savedMatrix;
- //tachometer
- GUI.DrawTexture(Rect(Screen.width*0.65, Screen.height*0.5, chronoTex.width/1.5, chronoTex.height/1.5), chronoTex);
- var centreTacho = Vector2(Screen.width*0.65 + chronoTex.width / 3, Screen.height*0.5+ chronoTex.height / 3);
- var savedTachoMatrix = GUI.matrix;
- var tachoFraction = RPM / topRPM;
- var needleTachoAngle = Mathf.Lerp(stopRPMAngle, topRPMAngle, tachoFraction);
- GUIUtility.RotateAroundPivot(needleTachoAngle, centreTacho);
- GUI.DrawTexture(Rect(centreTacho.x, centreTacho.y - dashboardArrow.height/3, dashboardArrow.width/1.5, dashboardArrow.height/1.5), dashboardArrow);
- GUI.matrix = savedTachoMatrix;
- speed = linkToBike.bikeSpeed;
- RPM = linkToBike.EngineRPM;
- function findCurrentBike(){
- var curBikeName : GameObject;
- curBikeName = GameObject.Find("rigid_bike");
- if (curBikeName != null){
- SetSpeedometerSettings("sport");
- return;
- function SetSpeedometerSettings(par : String){
- if (par == "sport"){
- topSpeed = 210;
- stopAngle = -215;
- topSpeedAngle = 0;
- topRPM = 12000;
- stopRPMAngle = -200;
- topRPMAngle = 0;
- yield WaitForSeconds(0.5);
- var linkToBike1 = GameObject.Find("rigid_bike").GetComponent("pro_bike5");
- linkToBike = linkToBike1;
点击此处复制文本
controlHub.cs
- using UnityEngine;
- using System.Collections;
- //this is script contains all variables translated to bike's script.
- //so, it's just a holder for all control variables
- //mobile/keyboard scripts sends nums(float, int, bools) to this one
- public class controlHub : MonoBehaviour {//need that for mobile controls
- public float Vertical;//variable translated to bike script for bike accelerate/stop and leaning
- public float Horizontal;//variable translated to bike script for pilot's mass shift
- public float VerticalMassShift;//variable for pilot's mass translate along bike
- public float HorizontalMassShift;//variable for pilot's mass translate across bike
- public bool ESPMode;//variable for turn ESP on and off
- public bool rearBrakeOn;//this variable says to bike's script to use rear brake
- public bool restartBike;//this variable says to bike's script restart
- public bool fullRestartBike; //this variable says to bike's script to full restart
- public bool reverse;//for reverse speed
点击此处复制文本
4.场景中相机的跟随和切换类:camSwitcher.cs;
- public class camSwitcher : MonoBehaviour
- public Camera backCamera;
- public Camera aroundCamera;
- public Transform cameraTarget;
- private Camera currentCamera;
- //////////////////// for back Camera
- float dist = 3.0f;
- float height = 1.0f;
- //////////////////// for around Camera
- private float distance = 3.0f;
- private float xSpeed = 10.0f;
- private float ySpeed = 10.0f;
- private float yMinLimit = -90;
- private float yMaxLimit = 90;
- private float distanceMin = 2;
- private float distanceMax = 10;
- private float x = 0.0f;
- private float y = 0.0f;
- private float smoothTime = 0.2f;
- private float xSmooth = 0.0f;
- private float ySmooth = 0.0f;
- private float xVelocity = 0.0f;
- private float yVelocity = 0.0f;
- //new camera behaviour
- private float currentTargetAngle;
- private GameObject ctrlHub;// gameobject with script control variables
- private controlHub outsideControls;// making a link to corresponding bike's script
- // Use this for initialization
- void Start ()
- outsideControls = ctrlHub.GetComponent<controlHub>();//to connect c# mobile control script to this one
- backCamera.enabled = true;
- aroundCamera.enabled = false;
- currentCamera = backCamera;
- if (GetComponent<Rigidbody> ()) GetComponent<Rigidbody> ().freezeRotation = true;
- currentTargetAngle = cameraTarget.transform.eulerAngles.z;
- // Update is called once per frame
- void LateUpdate ()
- #if UNITY_STANDALONE || UNITY_WEBPLAYER// turn camera rotaion ONLY for mobile for free touch screen anywhere
- if (Input.GetMouseButton (1)) {
- backCamera.enabled = false;
- aroundCamera.enabled = true;
- backCamera.gameObject.SetActive (false);
- aroundCamera.gameObject.SetActive (true);
- currentCamera = aroundCamera;
- x += Input.GetAxis ("Mouse X") * xSpeed;
- y -= Input.GetAxis ("Mouse Y") * ySpeed;
- y = Mathf.Clamp (y, yMinLimit, yMaxLimit);
- xSmooth = Mathf.SmoothDamp (xSmooth, x, ref xVelocity, smoothTime);
- ySmooth = Mathf.SmoothDamp (ySmooth, y, ref yVelocity, smoothTime);
- distance = Mathf.Clamp (distance + Input.GetAxis ("Mouse ScrollWheel") * distance, distanceMin, distanceMax);
- currentCamera.transform.localRotation = Quaternion.Euler (ySmooth, xSmooth, 0);
- currentCamera.transform.position = currentCamera.transform.rotation * new Vector3 (0.0f, 0.0f, -distance) + cameraTarget.position;
- } else {
- #endif
- backCamera.gameObject.SetActive (true);
- aroundCamera.gameObject.SetActive (false);
- //////////////////// code for back Camera
- backCamera.fieldOfView = backCamera.fieldOfView + outsideControls.Vertical * 20f * Time.deltaTime;
- if (backCamera.fieldOfView > 85) {
- backCamera.fieldOfView = 85;
- if (backCamera.fieldOfView < 50) {
- backCamera.fieldOfView = 50;
- if (backCamera.fieldOfView < 60) {
- backCamera.fieldOfView = backCamera.fieldOfView += 10f * Time.deltaTime;
- if (backCamera.fieldOfView > 60) {
- backCamera.fieldOfView = backCamera.fieldOfView -= 10f * Time.deltaTime;
- float wantedRotationAngle = cameraTarget.eulerAngles.y;
- float wantedHeight = cameraTarget.position.y + height;
- float currentRotationAngle = currentCamera.transform.eulerAngles.y;
- float currentHeight = currentCamera.transform.position.y;
- currentRotationAngle = Mathf.LerpAngle (currentRotationAngle, wantedRotationAngle, 3 * Time.deltaTime);
- currentHeight = Mathf.Lerp (currentHeight, wantedHeight, 2 * Time.deltaTime);
- Quaternion currentRotation = Quaternion.Euler (0, currentRotationAngle, 0);
- currentCamera.transform.position = cameraTarget.position;
- currentCamera.transform.position -= currentRotation * Vector3.forward * dist;
- currentCamera.transform.position = new Vector3 (currentCamera.transform.position.x, currentHeight, currentCamera.transform.position.z);
- currentCamera.transform.LookAt (cameraTarget);
- //New camera features.
- //Now camera leaning with biker, so horizon is not always horizontal :)
- //If you don't like it, just disable
- //from this -----------------------------------------------------------------------
- // rotate camera according with bike leaning
- if (cameraTarget.transform.eulerAngles.z >0 && cameraTarget.transform.eulerAngles.z < 180) {
- currentTargetAngle = cameraTarget.transform.eulerAngles.z/10;
- if (cameraTarget.transform.eulerAngles.z >180){
- currentTargetAngle = -(360-cameraTarget.transform.eulerAngles.z)/10;
- currentCamera.transform.rotation = Quaternion.Euler (height*10, currentRotationAngle, currentTargetAngle);
- //to this -------------------------------------------------------------------------
- #endif
点击此处复制文本
5.讲到这一步是比较关键的,正是通过GUI做出虚拟摇杆,虚拟摇杆控制类:mobileControls.cs;
- using UnityEngine.UI;//need that for mobile controls
- using UnityEngine.EventSystems;//need that for mobile controls
- public class mobileControls : MonoBehaviour, IDragHandler, IPointerUpHandler, IPointerDownHandler {//need that for mobile controls
- public Image bgImgJoyRight; //UI object for right Joystick
- public Image bgImgJoyLeft; //UI object for left Joystick
- private Image joystickImg; //"picture" of stick itself
- private Image joystickImgLeft;//"picture" of stick itself for joyLeft
- private Vector3 inputVector; //this will be translated to bike script for bike accelerate/stop and leaning
- private Vector3 inputVectorLeft;//this will be translated to bike script for pilot's mass shift
- //public bool ESPMode;//this variable switch ESP on and off
- private GameObject ctrlHub;// making a link to corresponding bike's script
- private void Start(){
- outsideControls = ctrlHub.GetComponent<controlHub>();// making a link to corresponding bike's script
- joystickImg = bgImgJoyRight.transform.GetChild(0).GetComponent<Image>();//find stick
- joystickImgLeft = bgImgJoyLeft.transform.GetChild(0).GetComponent<Image>();//find stick
- //Uncomment it if you want to lean by device rotation :)
- //from here---------------------------------------------------
- //private void Update(){
- // outsideControls.Horizontal = Input.acceleration.x*1.25f;
- //to here---------------------------------------------------
- //don't forget to comment standard leaning style few strings below
- ///////////////////////////////////////// Joystick Section /////////////////////////////////////////////////////////////////////////////////////
- public virtual void OnDrag(PointerEventData ped){
- Vector2 pos;//position for joystick Right
- if (RectTransformUtility.ScreenPointToLocalPointInRectangle (bgImgJoyRight.rectTransform, ped.position, ped.pressEventCamera, out pos)) {
- if (ped.position.x > Screen.width/2) {//use buttons should't take effect to joystics
- pos.x = (pos.x / bgImgJoyRight.rectTransform.sizeDelta.x);
- pos.y = (pos.y / bgImgJoyRight.rectTransform.sizeDelta.y);
- inputVector = new Vector3 (pos.x * 2 + 1, 0, pos.y * 2 - 1);
- inputVector = (inputVector.magnitude > 1.0f) ? inputVector.normalized : inputVector;
- //move stick
- joystickImg.rectTransform.anchoredPosition =
- new Vector3 (inputVector.x * (bgImgJoyRight.rectTransform.sizeDelta.x / 2), inputVector.z * (bgImgJoyRight.rectTransform.sizeDelta.y / 2));
- outsideControls.Vertical = inputVector.z;
- //Comment it if you want to lean by device rotation :)
- outsideControls.Horizontal = inputVector.x;
- //don't forget to uncomment rotate leaning style few strings above
- Vector2 pos_j2;//position for joystick Left
- if (RectTransformUtility.ScreenPointToLocalPointInRectangle (bgImgJoyLeft.rectTransform, ped.position, ped.pressEventCamera, out pos_j2)){
- if (ped.position.x < Screen.width/2 && ped.position.y < 170){//use buttons should't take effect to joystics
- pos_j2.x = (pos_j2.x / bgImgJoyLeft.rectTransform.sizeDelta.x);
- pos_j2.y = (pos_j2.y / bgImgJoyLeft.rectTransform.sizeDelta.y);
- inputVectorLeft = new Vector3(pos_j2.x*2 + 1,0,pos_j2.y*2 - 1);
- inputVectorLeft = (inputVectorLeft.magnitude > 1.0f)?inputVectorLeft.normalized:inputVectorLeft;
- //move stick
- joystickImgLeft.rectTransform.anchoredPosition =
- new Vector3(inputVectorLeft.x * (bgImgJoyLeft.rectTransform.sizeDelta.x/2) ,inputVectorLeft.z * (bgImgJoyLeft.rectTransform.sizeDelta.y/2));
- outsideControls.VerticalMassShift = inputVectorLeft.z;
- outsideControls.HorizontalMassShift = inputVectorLeft.x;
- /////////////////////////////////////////// pointer function ////////////////////////////////////////////////////////////////////
- public virtual void OnPointerDown(PointerEventData ped){
- if (ped.pointerEnter.name == "Stick") OnDrag(ped);
- if (ped.pointerEnter.name == "Button_X") outsideControls.rearBrakeOn = true;
- if (ped.pointerEnter.name == "Button_R") outsideControls.restartBike = true;
- if (ped.pointerEnter.name == "Button_Rf") outsideControls.fullRestartBike = true;
- if (ped.pointerEnter.name == "Button_E") {//we need to switch ESP on and off after each press on the ESP key
- if(!outsideControls.ESPMode){
- outsideControls.ESPMode = true;
- } else {
- outsideControls.ESPMode = false;
- if (ped.pointerEnter.name == "Button_rev") outsideControls.reverse = true;
- public virtual void OnPointerUp(PointerEventData ped){
- inputVector = Vector3.zero;
- joystickImg.rectTransform.anchoredPosition = Vector3.zero;
- inputVectorLeft = Vector3.zero;
- joystickImgLeft.rectTransform.anchoredPosition = Vector3.zero;
- outsideControls.rearBrakeOn = false;
- outsideControls.restartBike = false;
- outsideControls.fullRestartBike = false;
- outsideControls.Vertical = 0;
- outsideControls.Horizontal = 0;
- outsideControls.VerticalMassShift = 0;
- outsideControls.HorizontalMassShift = 0;
点击此处复制文本
6.最后直接运行看效果。【PS:HAHA!有空动手练练也是蛮有趣的】
