--------熔炉4 Unity插件:DOTween Pro 0.9.550
94
6
价格:80元素币(或8余额) 百度网盘 销售总额:480元素币 购买人数:6
尊敬的游客 ,本内容需要支付 80元素币十分之一的[余额] 来购买.
此资源为0.9.550版本
This extension requires one license per seat
Requires Unity 4.6.0 or higher.
WORKS WITH UNITY 5 and Unity 4.6 or higher (will automatically add dedicated libraries based on your Unity version).
See FULL CHANGELOG here
BETA VERSION All advertised features are present, but more stuff will be added along the way.
If upgrading from a version older than 0.9.100 please follow these instructions.
DOTween Pro extends the free engine DOTween, implementing new features both for scripting and visual scripting, including extra features for these external assets (if present):
- 2D Toolkit
- TextMesh Pro
VISUAL ANIMATION EDITOR
A Component that allows to animate some of its gameObject's properties without scripting: Move, Fade, Color, Rotate, Scale, Punch, Shake, Text, Camera properties and more.
Works also with 2D Toolkit and TextMesh Proobjects.
Implements a smart setup that allows you to easily interact with the animations via Unity UI onClick events.
VISUAL PATH EDITOR
A Component that allows you to animate its gameObject along a path.
VISUAL EDITOR MANAGER
An extra Component that can be added from a Path or Animation Editor. It allows to set additional actions to execute when its gameObject is activated or deactivated(especially useful when using a pool system)
ADDITIONAL DOTWEEN SCRIPT FEATURES
- Additional shortcuts for 2D Toolkit and TextMesh Pro, if present.
- DOSpiral shortcut.
1.0
参与人数 3 活跃度 +31
元素战争  发表于 2017-2-8 09:58:40
RE: Unity插件:DOTween Pro 0.9.550
带你赚币带你飞,元素里面有正妹!
gulup  发表于 2017-4-20 11:03:10
找不到最新包的
凉拌、  发表于 2017-4-21 09:13:52
带你赚币带你飞
ChaosX  发表于 2017-5-11 23:09:00
资源发布哪家强?元素首发称大王!
濄客~  发表于 2018-7-5 13:26:18
资源哪里好,肯定元素找
nantian 实名
21 小时
短杖 学徒法袍 长枪
