element3ds.com
引擎渲染作品 写的一个卡通shader
4499
12
我初学者   大家多多指导
Shader "MyToon/Toon-Surface_Normal" {
    Properties {
        _MainTex ("Base (RGB)", 2D) = "white" {}
        _Bump ("Bump", 2D) = "bump" {}
        _Ramp ("Ramp Texture", 2D) = "white" {}
        _Tooniness ("Tooniness", Range(0.1,20)) = 4
        _OutlineColor("Outline Color", Color) = (0,0,0,1)
                _Outline("Outline Width", Range(.0, 2)) = .5
    SubShader {
        Tags { "RenderType"="Opaque" }
        LOD 200
        CGPROGRAM
        #pragma surface surf Toon
        sampler2D _MainTex;
        sampler2D _Bump;
        sampler2D _Ramp;
        float _Tooniness;
        float _Outline;
        struct Input {
            float2 uv_MainTex;
            float2 uv_Bump;
            float3 viewDir;
        void surf (Input IN, inout SurfaceOutput o) {
            half4 c = tex2D (_MainTex, IN.uv_MainTex);
            o.Normal = UnpackNormal( tex2D(_Bump, IN.uv_Bump));
            half edge = saturate(dot (o.Normal, normalize(IN.viewDir)));
            edge = edge < _Outline ? edge/4 : 1;
            o.Albedo = (floor(c.rgb * _Tooniness)/_Tooniness) * edge;
            o.Alpha = c.a;
        half4 LightingToon(SurfaceOutput s, fixed3 lightDir, half3 viewDir, fixed atten)
            float difLight = dot (s.Normal, lightDir);
            float dif_hLambert = difLight * 0.5 + 0.5;
            float rimLight = dot (s.Normal, viewDir);
            float rim_hLambert = rimLight * 0.5 + 0.5;
            float3 ramp = tex2D(_Ramp, float2(rim_hLambert, dif_hLambert)).rgb;
            float4 c;
            c.rgb = s.Albedo * _LightColor0.rgb * ramp * atten * 2;
            c.a = s.Alpha;
            return c;
        ENDCG
                ZWrite on
                Cull Front
                CGPROGRAM
       #pragma surface surf Standard fullforwardshadows vertex:vert
                #include "UnityCG.cginc"
                #pragma target 3.0
                struct Input {
                        float2 uv_MainTex;
                float4 _OutlineColor;
                inline fixed4 LightingOutline(SurfaceOutputStandard s, UnityGI gi)
                        return _OutlineColor;
                inline void LightingOutline_GI(SurfaceOutputStandard s, UnityGIInput data, inout UnityGI gi)
                        gi = UnityGlobalIllumination(data, 1.0, s.Normal);
                float _Outline;
      void vert (inout appdata_full v) {
                v.vertex.xyz+=v.normal*_Outline;
          void surf (Input IN, inout SurfaceOutputStandard o) {
                        o.Albedo = _OutlineColor;
                        o.Alpha = 1;
          ENDCG
    FallBack "Diffuse"
  借用网上模型  如果有IP之类冲突  联系我删除   !!
参与人数 3 元素币 +50 活跃度 +21 贡献值 +1
YuFeiNiao  发表于 2017-7-20 10:05:15
没有效果图,,看不懂~~~~·
火多多  发表于 2017-7-20 11:55:18
linnan0807 发表于 2017-7-20 10:05
没有效果图,,看不懂~~~~·
之前不知道 怎么发图  刚刚加上
星爷万岁  发表于 2017-7-20 16:18:08
不错的shader
火多多  发表于 2017-7-21 12:29:41
我是初学者  多多指导
汉堡  发表于 2017-8-22 11:01:36
没图不懂
idrsky  发表于 2017-9-5 17:24:25
看看
炽炎红尘  发表于 2018-10-18 10:21:52
请选择您此刻的心情图片并写下今天最想说的话!
tim_chen  发表于 2018-11-22 13:41:26
下午好
⊙_⌒咚  发表于 2018-11-22 13:42:54
不知道怎么用
tyzyu  发表于 2018-11-22 14:13:46
从业不识微元素,做遍项目也枉然
qq_奔波儿灞_xU9  发表于 2020-12-3 15:55:08
666666666666666666666
神佛之上  发表于 2022-11-22 23:28:32
给力!元素有你更精彩
火多多 实名
61 小时
长枪
