CG视频教程 [动画特效] Endorphin角色动画模拟教程 - Simulating Creatures in Endorphin
552
75
视频教程
CG教程: 动画|动作
语音:
字幕:
清晰度:
版权声明: -
Endorphin角色动画模拟教程 - Simulating Creatures in Endorphin - cmiVFX
本视频介绍使用Endorphin所有功能,以模拟任何形式的拍摄真实的行为和动作创建自定义的动物(马和人在这个过程中)的主题。在此视频中使用的学习结构,齿轮的所有用户最多能够按照其内容,从开始到结束。这是为数不多的其中一个视频制作阙允许一个新手还是经验丰富的用户内啡肽学习在同一水平上的能力。通过这段视频所产生的结果是真正一流的,并且几乎不可能实现任何其他方式。有了这个革命性的融合技术,每个用户都可以要明白构建默认的字符的根源和原则,这样你就可以改变它的形状为一个自定义的生物,并操纵其行为的能力。在这同一个团队,你将学习如何无缝传输(不带任何插件或软件互操作性),内啡肽和您最喜爱的3D应用程序之间(我们使用了Autodesk Maya来证明)。当你的视频后,您将有机会为您定制的生物创建非常复杂的动作,在非常困难的情况下,如冲击,瀑布,和其他任何你可以梦想。
This video covers topics in creating custom creatures ( horse and human in this course ) using all features of Endorphin to simulate realistic behavior and movement for any kind of shot. The learning structure used in this video, gears all users up to be able to follow its contents from start to end. This is one of the few videos made that allow a novice or experienced Endorphin user the ability to learn on the same level. The results produced by this video are truly superb, and near impossible to achieve any other way. With this revolutionary blend of technology, every user can have the ability to understand the roots and principles of constructing default characters so you can change its shape into a custom creature and manipulate its behavior. At this same time, you will learn how to seamlessly transfer (without any plug-ins or interoperability software) between Endorphin and your favorite 3D application (We use Autodesk Maya to demonstrate). When you're finished with the video, you will have the opportunity to create very complicated movements for your custom creatures, in very difficult scenarios, such as impacts, falls, and anything else you can dream up.
参与人数 1 元素币 +1
左左右右  发表于 2015-7-12 17:55:01
太感谢楼主啦分享教程,很有价值。
heibaidemao  发表于 2015-7-12 20:51:32
感谢分享·················
tdm0612  发表于 2015-7-12 23:19:37
资源太好啦!!!谢谢楼主!!!
Zh_Jason  发表于 2015-7-12 23:39:10
好资源~支持点赞
1204933144  发表于 2015-7-13 07:54:25
元素帖子强,满满正能量!
1404226604  发表于 2015-7-13 08:03:52
元素帖子强,满满正能量!
feng942698  发表于 2015-7-13 09:30:55
好教程啊啊啊啊
miko  发表于 2015-7-13 13:04:14
为了元素币,拼了!
miko  发表于 2015-7-13 13:04:18
为了元素币,拼了!
miko  发表于 2015-7-13 13:04:22
立刻提起了精神。
miko  发表于 2015-7-13 13:04:24
立刻提起了精神。
中国小爷们  发表于 2015-7-28 22:30:55
我和我的小伙伴们都惊呆了!
cx4327  发表于 2016-7-18 14:54:52
带你赚币带你飞,元素里面有正妹!
HXDD12  发表于 2016-7-18 14:56:49
{:1_145:}
HXDD12  发表于 2016-7-18 14:59:30
17#
{:1_152:}
HXDD12  发表于 2016-7-18 14:59:35
18#
{:1_146:}
HXDD12  发表于 2016-7-18 14:59:40
19#
{:1_149:}
HXDD12  发表于 2016-7-18 14:59:45
20#
{:1_150:}
1234下一页
2435312822zjj 实名
38 小时
