Unity3D资源 [功能/工具] 流式地形加载插件World Streamer 2 1.4
108
3
引擎插件类型
软件版本要求: Unity2019.3.0或更高
引擎插件类型: 模型|贴图 辅助建模 材质|Shader
价格:50元素币收益:300元素币 销量:6
尊敬的游客 ,本内容需要支付后可见.
当前资源版本是1.4,官网最新版是1.5该资源仅供学习,商用请到正版地址购买https://assetstore.unity.com/packages/tools/terrain/world-streamer-2-176482
IMPORTANT: This tool is for advanced unity users
Pack support unity:
- Unity 2019
- Unity 2020
- Unity 2020.3+ LTS HD RP 10.3+
- Unity 2020.3+ LTS URP 10.2+
- Unity 2020.3+ LTS HD RP 10.7+
- Unity 2020.3+ LTS URP 10.7+
- Unity 2021
- Unity 2021.1+ HD RP 11.0+
- Unity 2021.1+ URP 11.0+
- Unity 2021.2+ HD RP 12.1+
- Unity 2021.2+ URP 12.1+
- Unity 2021.3+ LTS HD RP 12.1+
- Unity 2021.3+ LTS URP 12.1+
To run HD or URP please import pack to HD or URP project and then import support pack which is inside the asset in "HD and URP support" folder. It will replace shaders, prefabs, meshes so they will work with RP out of the box. Please also check readme files inside that folder.
World Streamer is a memory streaming and optimization system. By using it you are able to stream whole your game from a disc in any axis and space or simply change background of your scene into low poly representation. You are able to create endless space games, 2D platformers, 3rd person, cloud point viewers, or any kind of game you want without loading screens during player movement. You could also create endless looped world. In few clicks your game is ready to be loaded from your disc! Now your scenes are as big as you want, without any limits. You could work on local area and update world by 2 buttons in our local area updater. You could also separate your world into layers like: lighting, ai, geometry or even separate them into local areas. It's perfect soluton for teams that work on the same area. World streamer is also useful for architectural presentation or in any application that you need to use as low memory as possible. With streaming you will reduce objects count in your scene. Thats will save your cpu,gpu power and you will only load them if they are necessary. Collider streaming give you ability to stream rooms and floors, only when player will hit room/floor area collider. You could build whole towns with interiors without performance hit. Ring streaming will replace your unity terrains by low poly meshes in far distance. Now you are able to stream your open world from disc in few clicks.
Features:
- floating point error fix system
- looped world system
- low poly mesh background generator for terrain and trees (NatureManufacture and trees with crosses)
- multi scene editing support
- multiple layers streaming
- support for multiple devs working at one area
- removes world size restrictions and slow down in unity editor at huge or extremely detailed scenes
- ring streaming (replacement of the objects according to the distance)
- collider hit streaming option
- support for extremely big worlds
- easy automatic processes will save your development time
- in few clicks you can stream endless world
- work in any axis and space: 2d, 3d, vertical, horizontal
- reduce RAM,CPU,GPU,VRAM usage of your game
- reduce number of objects in your scene
- spawned player support
- physics manager
- load your world in background ( async loading )
- compatible with amplify, graphine and any other texture stream system
- loading screen system
- LOD system for split terrains
- Our floating point system support unity dynamic navmesh
- innovative local area updater
- terrain culling system based on camera view
- GI and lighting manager
- Occlusion Culling support
- terrain manager to cut your terrain into parts
- fully commented opensource code that will help you to work with World Streamer!
- direct Atavism MMO system support.
- HD and URP support
参与人数 1 元素币 +3 活跃度 +10
啊哈,窝窝头!
熾天之翼  发表于 2022-5-7 13:56:45
Teny  发表于 2022-5-7 20:33:24
谢谢楼主分享!!!
0anye0  发表于 2022-5-14 08:38:10
大佬继续努力更新最新版
WeBlackKnight 实名
开发工程师
1239 小时
长剑 钢剑 元素铜币 短杖 长枪 学徒法袍 【绝】真-红龙战甲 无色原始矿 绿母翠晶矿 彗星钛晶矿 阿尔法晶矿 火元素 粽子 【绝】千人纪念徽章 粒粒皆辛苦
