Unity3D资源 [功能/工具] [unity插件] Dragons Pack PBR Version 27 - 超屌魔龙动作模型资源包PBR(百度网盘)
205
1
引擎插件类型
软件版本要求: 要求Unity 5.3.4或更高版本。----(使用5.4导入测试,往下有资源图文介绍)
引擎插件类型: 模型|贴图
价格:466元素币(或46余额) 百度网盘 销售总额:466元素币 购买人数:1
尊敬的游客 ,本内容需要支付 466元素币十分之一的[余额] 来购买.
资源包名:  Dragons Pack PBR Version 27
3D模型/角色/生物
发布者:S.F. Bay Studios, Inc.
价格:$59
适用版本:要求Unity 5.3.4或更高版本。----(使用5.4导入测试,往下有资源图文介绍注意哟,资源包中只有魔龙和蛋。没有角色。角色是另外一个资源包
文件大小:336.28MB(导入U3D实际1G多)
资源有问题.或者链接不存在.请私信.看到立马解决
Asset store 链接:https://www.assetstore.unity3d.com/cn/#!/content/45330
插件仅用于学习。如需商用,请购买正版。----想要成大触,天天上元素!
资源介绍:
Requires Unity 5.3.4 or higher.
COMING SOON: Mesh Morphing using Blend Shapes, allowing you to customize the physical mesh for massive randomization & customization.
Full audio to match all the animations.
Dragons Pack PBR is a detailed, realistic, animated character package with customizable textures. Mobile Friendly & Cinematic Ready.
They features both flying & ground animations, and Animation Layers can be used to drastically increase the attack & magic animations.
Comes with three heads, four back options, two tails and unlimited texture customization.
Also includes a \"Dragon Egg\" model that features TWO base textures and 100% customization. The package now also features the...
DRAGON RIDER BONUS
For users who also have the RPG Barbarian Pack PBR, the \"Dragon Rider\" can be used. Check the PDF/YouTube for instructions,
but now your Human character can ride on the back of the dragon, fully animated to work with all of the Dragon animations.
CUSTOMIZE TEXTURES
Use sliders to adjust the look & feel of the Dragons. Easily change colors, add special effects like dirt, mud, blood, ice, snow, moss & more.
It\'s fast and allows you to create any number of looks that perfectly suit your game. Main texture maps are 2048x2048.
Includes helper scripts that make it easy to change shared options on multiple materials at once.
ANIMATIONS
Dragon Rider animations include data for theRPG Barbarian Pack PBR.
• Attack 01
• Attack 02
• Breathe Fire
• Death
• Fire Head 01 (Head/Neck Only)
• Fire Head 02 (Head/Neck Only)
• Fly
• Fly Attack
• Fly Backward
• Fly Breathe Fire
• Fly Death 01 (Loop Start)
• Fly Death 02 (Loop)
• Fly Death 03 (Loop End)
• Fly Dive
• Fly Fast
• Fly Glide
• Fly Got Hit
• Fly Idle
• Fly Static Saddle (Fly Forward w/ Saddle as center of mass)
• Got Hit 01
• Got Hit 02
• Idle
• Idle Break
• Look Back Left 01 (Loop Start)
• Look Back Left 02 (Loop)
• Look Back Left 03 (Loop End)
• Look Back Right 01 (Loop Start)
• Look Back Right 02 (Loop)
• Look Back Right 03 (Loop End)
• Run
• Tail Whip Left
• Tail Whip Right
• Walk
• Walk Backward
POLYCOUNT
We provide multiple LODs from High Poly (good for cinematics) to Low Poly (great for mobile).
A full dragon ranges from ~4,000 to ~30,000 depending on the LOD chosen.
PARTICLES
Magic particles included. Includes our full \"Magic Spells & Particles\" package so you can create your own unique effects.
PBR
The Dragons use real PBR values, not half-baked or made up PBR. We start out with real world materials and you can adjust from there.
Maps included: Diffuse | Normal | Roughness | Metallic | Ambient Occlusion
LEGACY SHADERS
Don’t be fooled by the “requires Unity 5” message! The textures our system exports work with legacy shaders the same way any other character you already have does.
You’ll need Unity 5 to set up the textures, but once exported, you can bring them in to ANY Unity version and they’ll work.
TEXTURES
Comes with a pre-made base texture. Use sliders to adjust the colors, roughness of various sections. Use sliders to add environment FX like Dirt, Snow, Grunge & more.
---------------------------------------------------------------------------------------------机器翻译---------------------------------------------------------------------------------------------------------------------
即将到来:使用混合网格变形形状,允许您定制的物理网格大规模随机化和定制。
完整的音频匹配所有的动画。
龙包PBR详细,真实,动画角色包和可定制的纹理。移动友好&电影做好准备。他们飞行和地面特征的动画,动画层可以用来大幅度增加攻击和魔法动画。
有三个头,四个选项,两个尾巴和无限的纹理定制。还包括一个“龙蛋”模型,具有两个基本纹理和100%的定制。现在的包还包括……
龙骑士的奖金
的用户也有RPG野蛮人包PBR,可以使用“龙骑士”。检查PDF / YouTube的指令,但现在你的人类性格可以骑龙,后面完全动画与龙的动画。
自定义纹理
使用滑块来调整龙的外观和感觉。容易改变颜色,添加特效如草芥,泥土、血液、冰、雪、苔藓和更多。它的速度非常快,允许您创建任意数量的看起来,完全适合你的游戏。主要纹理地图是2048高模。
包括辅助脚本使它容易改变一次选择多个材料共享。
动画
龙骑士动画包括PBR theRPG野蛮人包的数据。
•攻击01
•攻击02
•呼吸火
•死亡
•火头01(仅头部和颈部)
•火头02(仅头部和颈部)
•飞
•飞攻击
•向后飞
•飞呼吸火
•飞死01(循环开始)
•飞死02(循环)
•飞死03(循环结束)
•飞潜水
•快速飞
•飞滑翔
•被撞飞
•飞闲置
•飞静态鞍(飞向前w /鞍质心)
•有打击01
•有打击02
•闲置
•空闲休息
•回顾左01(循环开始)
•回头离开02(循环)
•回顾左03(循环结束)
•回头对01(循环开始)
•回头对02(循环)
•回头对03(循环结束)
•运行
•尾鞭左
•尾鞭吧
•走
•向后走
多边形数
我们提供多个钟表从高聚(对动画)低聚(伟大的移动)。
一个完整的龙范围从4000 ~ ~ 30000根据所选择的LOD。
粒子
魔法粒子包括在内。包括我们的完整的“魔法咒语和粒子”包,这样你就可以创建自己的独特效果。
PBR
龙使用真正的PBR值,而不是半成品或者PBR组成。我们从现实世界的材料,从那里你可以调整。
地图包括:分散正常| |粗糙度|金属|环境闭塞
遗留的着色器
不要被“需要统一5”消息!纹理与遗留系统出口工作着色器同样的方式你已经有其他字符。
你需要统一5设置纹理,但是一旦出口,你可以带他们去任何统一的版本,他们会工作。
纹理
配有一个预制基础结构。使用滑块来调整颜色、粗糙度不同的部分。使用滑块添加环境外汇如草芥,雪,蹩脚货&更多。
导入U3D实例截图:
爱上一只猫 实名
377 小时
六维几何 长枪
