Unity3D资源 [特效工程] Unity AAA Stylized Projectiles Vol 1 v2.5.0 卡通特效资产
571
1
引擎插件类型
软件版本要求: 2020.3.18或更高
引擎插件类型: 动画|特效
价格:90元素币(或9余额) 百度网盘 销售总额:1260元素币 购买人数:14
尊敬的游客 ,本内容需要支付 90元素币十分之一的[余额] 来购买.
The asset includes:
- 28 unique projectiles (spells, fireballs, arrows, bullets, lasers and more) with the same style as AAA Magic Circles and Shields and 3D lasers Pack
- 27 unique hit effects
- 25 flash effects
- 96 textures
- 7 multipurpose particle shaders
- Demo scene shooting script
- Script to instantiate effects on particle collision (you can change position, rotation and number of effects)
WebGL Demo (High quality)
PC Demo (Ultra quality)
Supports built-in render by default. HDRP and URP are supported using this FREE package for Unity 2021 or below. It becomes free after purchasing one of my assets.
URP/HDRP is default from Unity 2022 or Unity 6+. Shader Graph is required which is installed together with this asset. Support package doesn't needed. Can be changed to built-in render.
All effects work on all platforms and are presented in normal sizes. You can easily resize effects using standard size values. Effects made in 3 versions:
- Moving through a script using transform.velocity (you can rewrite the script so the projectiles fly into the target)
- moving through speed in a particle system!
- 2D version only for SRP.
Works with Projectile Factory by InfinityPBR.
Check my another Projectiles pack, Toon projectiles pack and Toon projectiles 2!
Promo media (videos, images) uses post process "Bloom" from the Volume component.
Contact me if you have any problems or questions. Contact methods on the profile page.
参与人数 3 元素币 +22 活跃度 +6
游戏zx  发表于 2024-12-15 10:57:21
流光溢彩,炫目多芬
VFX_LYP 实名
178 小时
长枪 火元素
